Old 19th July 2009, 03:15 PM   #1
jaycee is offline jaycee  United Kingdom
Default Bias suggestions for Marantz PM-35
Ok so my Marantz PM-35 is now back to full health. All it needed was a few cracked joints retouching, and a replacement 7824 regulator.
I'm just wondering if its worth re-biasing. One of the channels measured 1.5mV across one of the 0.1R emitter resistors, the other measures about 2.0mV. I think thats about 15/20mA respectively. I just noticed test posts that are on the emitter pins of each transistor and wondered if i should measure across those using test clips for ease.
The amp is basically an NEC UPC1270H frontend with a pair of 2SA1263/2SC3180 outputs per channel. The VBE device is a 2SC3419. The bias trimmers themselves are 472 (4K7).
Whats bugging me is where to start. The datasheet for the 1207 shows the trimmer connected in the stupid way - from VBE collector to base. I'm not sure which arrangement the Marantz uses as I can't find a schematic.
I was thinking about setting 30mA per channel.
Bias and DC Offset Pots Marantz 2285B DreadPirate Solid State 6 9th August 2009 10:17 PM
Fixed Bias suggestions dsavitsk Tubes / Valves 12 22nd February 2008 03:22 AM
Need Marantz 2230 Bias Procedure mvarney Solid State 1 1st March 2007 04:58 AM
Marantz pm 94 + Bias adjusting CederPM94 Solid State 0 10th May 2004 09:22 AM
Marantz CD 40 schemas and DIY suggestions? seppstefano Digital Source 0 10th March 2004 08:00 AM
Page generated in 0.09574 seconds (52.92% PHP - 47.08% MySQL) with 10 queries
