Trying to save my Onkyo 504 amp
Old 19th July 2009, 04:00 PM   #1
Minicooper is offline Minicooper  United States
Default Trying to save my Onkyo 504 amp
I just joined this forum hoping someone can help me with my 10 year old M 504 power amp.
A week or so after a lighting strike near my house, I turned on my seldom used stereo system and it was silent. After checking it out a bit I determined the only problem seemed to be in the power amp. All the other components were fine, the 504 amp was lit up and looked OK, but had no output. I have since noticed that the "servo" light on the front of the amp is not lit. It appears that the "protection circuit" actuated and then failed to reset. There is no evidence in the amp of anything being burned or otherwise damaged.
Any ideas on the cost or difficulty of fixing it? To me it's a cool lookng amp that I have enjoyed over the years. I hate to just throw if away if it can be fixed for maybe !00 dollars or so?
Old 19th July 2009, 08:46 PM   #2
djoffe is offline djoffe  United States
Default a start...
at the minimum, you will need a schematic or service manual...
here's a site that had something close, I think, but you'll have to look further for the actual schematic...Now, if the 5060 was anything close, you had better know what you're doing, or take it to someone who does...
http://www.audio-circuit.dk/Schemati...060-pwr-sm.pdf
Old 20th July 2009, 03:57 AM   #3
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
As I recall, the M504 and 508 are very similar.
http://www.audio-circuit.dk/Schemati...508-pwr-sm.pdf
The M504 is a very good amp, however it is known for it's problems with the large PSU caps, which tents to blow due to the fact that their working voltage is only app. 5 volts above the actual rail voltage.
The reason why the protection circuit won't reset could be caused by serious DC voltage on the output. You have to check this before proceeding with any other repair try.
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 4th September 2009, 04:21 PM   #4
Phbrush is offline Phbrush
Default Onkyo M-504 Amplifier
I read a post of yours regarding problems with the servo circuit on an M-504 Onkyo. My meters are also pegged. There does not appear to be any voltage present on the amplifier output. If I ground the output of the protection circuit, the speaker relays pull in and the unit will operate normally, but the meters are still pegged. Any suggestions ? Thanks, Pete
Trying to save my Onkyo 504 ampHide this!Advertise here!
way to save a thread Robert McLean Everything Else 5 17th September 2008 11:54 AM
DJ Needs to Save Money dirtyk777 PA Systems 22 14th October 2006 07:11 PM
Aleph-x help me save it. anders.a Pass Labs 47 13th July 2006 06:46 AM
Can I save my tape deck? Brion55 Analogue Source 4 29th July 2005 06:36 AM
Scrap or save? Burnedfingers Tubes / Valves 11 6th September 2003 05:33 PM
Copyright ©1999-2017 diyAudio
