Old 18th July 2009, 07:20 PM   #1
VintageAmp's Avatar
Default Krell KBL & KPA
I have a KBL back on my bench. It seems the 15030 and 15031 keep failing. Does anyone have an idea about the selector switch in the power supply? S1 = 2 S2 + 1 and S3 = 1 Is this correct for 120 Vac operation? Since the output V out is +/- 77 Vdc I am beginning to think the XFMR tap is incorrect. The first set of transistors mounted to heat sinks get scary hot (in the power supply) but the unit seems to work fine other wise. Distortion and offset test fine.
Vintage Amp
Old 15th March 2010, 05:11 AM   #2
VintageAmp's Avatar
I decided to run the unit on a 100V autoformer and it has been operating for 6 months without failure. Power supply heat is way down.
Vintage Amp
Old 15th March 2010, 08:45 AM   #3
h_a is offline h_a  Europe
h_a's Avatar
Sounds a lot like a regulated supply running from the wrong windings. Try to measure the secondary voltages with a multimeter, should be a tad higher than the rails (maybe 10V or so).
Have fun, Hannes
Old 17th March 2010, 02:08 AM   #4
VintageAmp's Avatar
Default Krell regulation circuits
The power supply has 2 stages for each supply.
77V +/- rectified gets regulated to:
58V +/- and then gets regulated to:
48V +/- as it goes to the preamp. On the preamp board it gets regulated to 44V +/-
The other supply starts at 48V and ends at 21V after regulation.
I have checked the taps and confirmed the taps are set correct to 120 V operation. If I change the taps I get 220 V
Vintage Amp
Old 14th January 2012, 06:15 AM   #5
VintageAmp's Avatar
As of 1/12/12 the unit is still running at 100 VAC with no trouble.
Sound quality is very livable in the daily system. Cannot say its better then the Threshold T2 I use in the main room, but it is = or better then some older Thresholds. At any rate, they ALL need new caps.
Vintage Amp
Page generated in 0.10105 seconds (58.03% PHP - 41.97% MySQL) with 10 queries
