Using Power MOSfets Instead Of L Mosfet
Old 18th July 2009, 05:59 PM   #1
sekhar is offline sekhar  India
Default Using Power MOSfets Instead Of L Mosfet
I am new in this this field of audio amps . I have been consulting High Power Audio Amplifier Manual By G Randy Slone .
I want to make a 500W subwoofer amplifier but due unavailability of L Mosfet I am nt able to procced can any body tell how to use Power Mosfet(IRFP240/IRFP9140) instead of 2SK1058/2Sj162.
Old 18th July 2009, 07:56 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
IRF mosfet are HEXFET
they are very different than 2SK1058/2SJ152 = lateral mos
So, strongly not recommended to use them to replace.
In fact, you would have to change the original amplifier so much
that it would be a different amplifier.
Much Better to try to find some nice MOSFET amp
that is built to use IRFP240/IRFP9240
For example Nelson Pass has designed a couple of such amplifier projects.
lineup
Old 18th July 2009, 08:06 PM   #3
Spirtos is offline Spirtos  Greece
Spirtos's Avatar
There are great differences between vertical (IRFP) and lateral type of mosfets (2SK/J). Allthough both can be used in power amps better dont use vertical insted of lateral type in specific designs, specially R. Slone's designs need a lot of modifications to suit vertical type mosfets and after all it will not be the same amp. As Lineup said better find a design which uses vartical mosfet. Try some search and Im sure you ll find a lot. Nelson Pass' designs are a good start.
Where there is a "will" , there is a way! I hope...
Old 20th July 2009, 03:16 PM   #4
thanks a lot, but can u direct me towards any specific design. I am thinking about making "Citation 12" from the Nelson pass Labs or the IGBT amp from elector. Plz tell which is worth trying cause i have tried a lot of circuits from the net but many have failed ...... instead of the fact that i design my own pcbs.
And one more thing....... Plz tell if any heip needed on Pcbs ...... just upload the circuit I will try to send u the pcb
Old 20th July 2009, 04:27 PM   #5
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I would go with a modern IRFP design.
IRFP240 and IRFP9240 are cheap and plentiful.
I use them on my own designs and they perform very well.
PCBCAD51 pcb design software. 2018 version out now >>>>>> http://www.murtonpikesystems.co.uk
Old 20th July 2009, 04:39 PM   #6
Have a look at the various Quasi designs.
regards Andrew T.
Old 20th July 2009, 04:46 PM   #7
RS Components do IRFP250 at 1-49.
Cheap as chips !
www.rswww.com
Old 20th July 2009, 11:07 PM   #8
Thanks for the advise "nigelwright" . Can u Send me Some of your design I am nt able to find good quasi complementary design.
regards
Old 20th July 2009, 11:15 PM   #9
regards
I dont have a quasi design mine are all complementary using IRFP250 and IRFP9240.
There are loads of designs on here if you do a search for quasi.
Old 21st July 2009, 07:14 PM   #10
thanks "nigelwright" u can send ur complementary designs as well. I wanted to make quasi complementary amps because i didnt get L mosfets in India .
Neways currently I am making the following 125W design. If u can have a look at circuit plz it would be very helpful
regards
Using Power MOSfets Instead Of L MosfetHide this!Advertise here!
help about power amplifier mosfets milad-k800 Car Audio 1 23rd August 2008 10:26 PM
new power mosfets from IXYS ... mlloyd1 Pass Labs 6 27th April 2007 05:34 PM
Age-old Power MOSFETS again... Emmy Parts 2 2nd February 2005 12:06 PM
schematics for power mosfets? rx7speed Solid State 3 29th November 2004 09:45 PM
Power mosfets bigloop Solid State 5 3rd April 2004 08:58 PM
