#601 | |
Secondly, the so-called "true complementary" solid state amplifiers also not comparable with the tube amp in class-A operation (even not in pure class-A), because there are no P-CH tubes. Already through this fact tube amps for audio must be better in general cause the better matching of the two halves. This means clearly that only "Single Ended" and CSPP (PPP, Circlotron) solid state power stages in Class-A mode (by "Single Ended" unavoidable) are to compare with tube power stages, for avoiding to compare apples to pears or oranges. In light of these conditions, solid state amplifiers clearly outperform each tube amp in every respect. Otherwise there are heavy design error(s) in the solid state amplifier. Unfortunately there are not a wide range of such commercial solid state amps on the marked; commercial and diy (kit) examples I have listed there: URL Collection of Commercial Single Ended Integrated and Power Amplifier Devices and there URL collection of Totem Pole and CSPP (Single Ended related) Solid State Output Stage But nobody could show me until this day a commercial tube amplifier, which clear outperform the biggest single ended solid state amp series from Nelson Pass, the "Aleph" - e. g. the "Aleph 1.2" To outperform a normally solid state Amplifier in Class-AB mode with low transition aera from "A" to "B" (independend of the price class) is easy to show with most average tube amp, independend whether there are an ultralinear-, Single ended-, or PPP topology. Sadly but true is that the largest percentage of solid state audio amplifiers uses small amounts of quiescent currents and so called "True complementary" output devices in the output power stages. I love this by theoretical explantations for beginners and on the schematics, but I hate this in real life . This is for me even the only reason why so many music lovers (rightly) say's, solid state amplifier did sound unmusical (even in traditionally measured THD values that are extrem low and therefore hardly detectable). They have never heard unfortunately the other solid state amps like Aleph. Last edited by tiefbassuebertr; 10th January 2010 at 12:16 PM. |
#602 | |
A good news by time in time... ![]() Piercarlo |
#603 | |
Unless I'm really misunderstanding you, which is certainly possible, you seem to be saying that one reason that tubes are better is because they use the same polarity of output devices in both halves of the push-pull configuration. But there are a lot of solid state amps that have done this as well, like the Phase Linear 300, or the SUMO The Nine. If you find PNP/P-Channel devices undesirable, you can certainly build a solid state (any class) amplifier without them. |
#604 |
tiefbass,
please stick to facts, not opinions, when discusing SS vs Tube. |
#605 | |
jd
/Yes! Its out: Linear Audio Vol 5! I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun |
#606 | |
I'm no tube expert but I believe the KT88 is used a lot in audio output stages and I think it is a 40W device. How fast is the KT88 compared with n-channel 40W BJT, MOSFET, JFET (is there a 40W JFET?), IGBT?
“Simplicity is the ultimate sophistication.” Leonardo da Vinci |
#607 |
I believe even "fast" audio power output bjt are device physics limited
metal gate Mosfet "speed" however is primarily package parasitic limited in popular TO-220/247 leaded packaging IXYS RF: HF/VHF Linear MOSFETs |
#608 | |
What means "a lot of" for you ?? SUMO "The NINE" could be one of few exceptions, because it is an CSPP topology (see attachement), but I don't know about the idle current values. If it runs typically arround 50mA, nevertheless you cannot compare with tube amp. The Phase Linear 300 use low idle current values and therefore, it is not comparable anyway to any tube amp. To make long explanations short - the conclusion of my statement from previous is follow: By compare SS amps with tube amps, it is important to know, to allow only "Single Ended" and CSPP (PPP, Circlotron) solid state power stages in pure Class-A mode. This means first, that solid state Class AB modes are not to allow for compare (independend of topology), because I have never heard about tube amp devices for home hifi in Class AB (except any few OTL's) Secondly true complementary (also quasi complementary) SS in pure classA are also not to allow for the aim of comparsion to tube amp, because there are no tubes with reverse polarity. By breaking this rule the audible differences causes first through basically different operating modes and circuit topologies, but many musiclovers still believe to the superior properties of the tubes. Bonsai, all what I say are facts, not opinions - so I think. But if you want to convince me otherwise - please, be happy; I look forward to this. What means ":d :d :d" - please let me know I'm no expert for the typical abbreviations in the "Forums" language - sorry |
#609 |
Plinius ?
Not so much,.......if it says "ZM" in the corner. |
#610 |
Schematic SUMO NINE PLUS second try
| Output transistor power dissipation. | nigelwright7557 | Solid State | 11 | 26th May 2008 01:55 PM |
| Power horizontal deflection transistors work fine in output stages ? | aldovan | Solid State | 7 | 31st August 2007 01:31 PM |
| sziklai-darlington diamond buffer (SDDB) for power output stages | mtlin12 | Solid State | 5 | 1st April 2005 06:55 AM |
| power transistor output capacitance | hienrich | Solid State | 3 | 26th December 2004 07:18 AM |
