bipolar (bjt) transistor families for audio power output stages
Old 16th December 2009, 02:53 PM   #31
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
BV,
as stated, measurements say nothing. For me the perceived sound that counts, since my approach is not commercial, I don`t need to prove anything to anybody. I meant linearity according to the ear`s own scale (quite different from artificial made-up scales).
Old 16th December 2009, 03:57 PM   #32
Juergen Knoop is offline Juergen Knoop  Germany
Juergen Knoop's Avatar
Originally Posted by Lumba Ogir View Post
BV,
So the japanese manufacturers build their parts according to someones or yours 'ear scale'?
Do Toshiba or Sanken do their quality control by listening?
Old 16th December 2009, 04:02 PM   #33
BV is offline BV  Slovakia
Lumba, if You preferred "rich, warm, musical..." sound (with high level of low order distortion and IMD product) , it is OK, it is Your taste.. But then please talk not about technical facts as linearity and technology of "switching" devices, and especially not about "linearity according to the ear`s own scale" .
PMA had made on our local forum test, he posted recording with various levels of low order added distortion (without information what he made) . Even "golden ears" cannot hear and tell what is diference between tracks, and distortion levels was about 1% and more .
You are right in one point, measurements say nothing, but only about personal preferences. They can tell quite all about objective performance , off course not single 1kHz THD+N measurement.
Old 16th December 2009, 05:09 PM   #34
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
BV,
In case of the traditional measuring methodes (THD 1000 Hz, IM 19/20KHz) you are right.
But with the appropriate measurements, I would get a fairly accurate statement about the amp sound character without having heard him oneself.
Unfortunately, it is so, that nobody uses such measuring methods. Or even so that nobody wants to use such methods of measurement. Thus, discussion like this are still present by this forum, but also in others.
An easy way to find out an exactly attestation regarded different sonic quality (and different distortion measurement) through different ft's and different emitter structures would be to create a ordinary complementary push pull darlington power follower without front end for voltage gain in the NFB loop, so that only the NFB through the follower topology itself have an effect (open loop gain not too high). The schematic by the Densen-thread here about
Densen amp
is a good topology therefore, if one remove the first stage of power buffer (please ignore the second schematic version).
The test must perform by two modes: pure Class-A and Class AB (20-50mA through the output devices).
Perhaps one of the members can perform and investigate this.
I recall a similar test report, where the old 2N3055 has been compared with modern parts of power devices (perhaps JLH-ClassA?) Unfortunately I have forget the download place in the web.
Old 16th December 2009, 05:13 PM   #35
R.I.P.
Originally Posted by wg_ski View Post
And you don't "need" a triple at the more-normal 200W level anymore.
I have shown a few times why I can't agree with that statement.
It's down to peak current delivery into reactive loads.
200W into 4r0 (within your limits of +-55Vdc) requires Vpk = 40Vpk and Ipk = 10Apk.
Into 4 ohm speaker load this demand can rise to around 30Apk.
This cannot be met from a two stage output EF not even with double complementary pairs in the final stage.
The peak current demand for 200W into 8ohms is not nearly as difficult to meet but it is way outside your +-55Vdc supply rail limit.
regards Andrew T.
Old 16th December 2009, 05:20 PM   #36
Banned
Juergen,
They don`t. Moreover, data sheets specifications do not signify sonic properties, but 80MHz is more promising than 4MHz. The general bandwidth / linearity relationship is known. Ultimately, a practical evaluation will tell, that can be done easily and reliably, no musical skills, no golden ears, all you need is a change in attitude.
Old 16th December 2009, 05:27 PM   #37
wahab is offline wahab  Algeria
it s quite doable...i use darlingtons MP1620/MN2488 with a beta of 6500 mini
at 7 A, and they are the second grade ,the first being 15000 mini....
using four in paralele, wich is a minimum for an amp.
loaded with 4R, it can provide the 30 amps with 4.6 mA of
total base current and 2 mA , respectively for the second and first
grades...
all is question of choice of components...sure that if you
use the classical beasts as the onsemi mjl + mje , it will fall short..
Old 16th December 2009, 05:28 PM   #38
R.I.P.
I recall Sanken doing a 60MHz device, but not a complementary pair.
I also think ONsemi are doing 45 to 50MHz devices.
Is there a reason why the performance should be much different when built into a real circuit designed to suit these devices.
regards Andrew T.
Old 16th December 2009, 05:31 PM   #39
R.I.P.
at 7 A,
I have not even bothered to look at the datasheet, but I will guarantee that this integrated Darlington will not perform as a well as a pair of Darlington connected discrete BJTs, over a range of realistic output currents.
regards Andrew T.
Old 16th December 2009, 05:33 PM   #40
The right approach for this you will find in this topology of Dynacord's stage power amp L-1600 resp. EV (Electro Voice) P2000 (still available) go to Owner's Manual for datas
http://www.electrovoice.com/documents/ev/p2000-eds.pdf
and the attachements (some schematics)
bipolar (bjt) transistor families for audio power output stagesHide this!Advertise here!
Output transistor power dissipation. nigelwright7557 Solid State 11 26th May 2008 01:55 PM
Power horizontal deflection transistors work fine in output stages ? aldovan Solid State 7 31st August 2007 01:31 PM
sziklai-darlington diamond buffer (SDDB) for power output stages mtlin12 Solid State 5 1st April 2005 06:55 AM
power transistor output capacitance hienrich Solid State 3 26th December 2004 07:18 AM
