Old 18th December 2009, 08:53 PM   #101
Location: Auburn, WA (somewhere between Seattle and Tacoma)
Send a message via ICQ to Damon Hill
A further question I'd like clarified is whether the thermal tracking diodes on the OnSemi and Sanken (anyone else?) transistors are part of the transistor's silicon die or are the just mounted adjacent to the die? I'd like to think they are integral for fastest response time, but I'll take what I can get.
Old 18th December 2009, 09:11 PM   #102
tiefbassuebertr's Avatar
Originally Posted by stinius View Post
Lumba
Since this thread is about audio power output stages what about comparing 2SA1943/2SC5200 with onsemi 3281/1302?
At the first look basicly not great differences. The 3281/1302 both available from TOKYO SHIBAURA ELECTRIC and On-Semiconductor - look at my first post (post #1).
In this case this thread could be also of interest:
Evaluation results: MJL3281A/MJL1302A SPICE Models
Old 18th December 2009, 09:25 PM   #103
stinius's Avatar
Hi Damon
The OnSemi tracking diodes is not a part of the silicon die.
Have a look at this thread, a lot of info.
On Semi ThermalTrak
Cheers
Old 18th December 2009, 09:44 PM   #104
mjf is offline mjf  Austria
[QUOTE
hello.
i think magnatec (semelab ) has them too.
Magnatec | Semiconductors | Discretes | Bipolar Transistors | PNP Power |2SA1302-0
greetings
Old 18th December 2009, 11:12 PM   #105
Banned
stinius,
thanks again for your kind help.
I`m extraordinarily glad to see that Motorola took the effort to develop the MJL3281/MJL1302 for linear applications. Copying the readily available 2SC3281/2SA1302, however, would have significantly reduced the high product development costs.
Old 18th December 2009, 11:13 PM   #106
wahab is offline wahab  Algeria
[QUOTE=Ultima Thule;2017244]Let me see, I had a second look to try understand how the information should be interpreted given in the data sheet and test circuit in attachment of post #71
It says 28,3 V RMS and 100 Watt @ output into 8 Ohm..
Let's see if we do the Ohms law calculation the 28,3^2 = 800...
P = U^2/R >>> 800/8 = 100 Watt
Upk (for sine) = U RMS * sqr2 >>> 28,3 * 1,414 = 40 Volt peak
alternatively we can calculate the power also as follow:
28,3 U RMS / 8 Ohm = ~3,54 A RMS
28,3 * 3,54 = 100 Watt
As I can see we have 10 Volts of headroom to the 50 Volt rails supply before clipping occures.
Wahab, correct me if I'm wrong here!?
If we do the simulation again with 80 Volt pk-2-pk and for both 240 mA and 52 mA what how would the distortion look then?
(Re for output transistor as in pots #71, eg. 0,5 Ohm)
Cheers Michael[/QUOTE
hi, michael
Peak current is 5A, so the maximum loss in the emitter degeneration
resistance is 0.5 X 5 = 2.5V....on each rail..
add the transistors losses..
here the graphs of THD for Iq of about 230 mA...
regards,
wahab
Old 18th December 2009, 11:52 PM   #107
stinius's Avatar
Originally Posted by Lumba Ogir View Post
stinius,
Lumba
You are too generous.
Since you liked the MJL3281/1302 (switching) devices, maybe you could have a look at the NJW devices as well, and the most interesting parts the NJL series aka TT ( these are the devices that Bob are talking about)
NJW
NJL
Old 18th December 2009, 11:53 PM   #108
Default more numbers..
i added the figures for a 10Khz frequency...
quite interesting..
regards,
wahab
Old 19th December 2009, 12:00 AM   #109
Lumba
the MJL3281/1302, more or less good copies of the (old) toshiba
2SA1302/2SC3281 are better than the MJL21193/21194...
the latter are gross rugged devices which are neither good in audio
nor in switching, unless it s slow frequency...they lack gain linearity..
Old 19th December 2009, 12:07 AM   #110
Ultima Thule's Avatar
Hi Wahab,
I think we can agree now it's far from clipping however we want to define headroom may be a semantic question anyway.
Thanks for making another simulation, it is interesting the simulator indicate the Toshiba having higher odd orders than even order in comparison to the ON-Semi, but these are anyway just simulations.
Output transistor power dissipation. nigelwright7557 Solid State 11 26th May 2008 01:55 PM
Power horizontal deflection transistors work fine in output stages ? aldovan Solid State 7 31st August 2007 01:31 PM
sziklai-darlington diamond buffer (SDDB) for power output stages mtlin12 Solid State 5 1st April 2005 06:55 AM
power transistor output capacitance hienrich Solid State 3 26th December 2004 07:18 AM
Copyright ©1999-2013 diyAudio
