Maplin mosfet problems
Old 15th July 2009, 09:29 AM   #1
bobcat is offline bobcat  United Kingdom
Default Maplin mosfet problems
Hi all i have just built one of these using a genuine board and all the correct discrete transistors all available from rs, but i have a problem the amp works fine but the driver tr's get very hot in fact too hot to touch after about an hour of normal use the supply voltage = 50 0 50, quiescent current is set to 100ma and there is virtually no dc at the output. Any help appreciated B\c
Old 15th July 2009, 09:58 AM   #2
what bias current passes the drivers in the quiescent state?
What heatsinks are fitted to the drivers?
Are the driver Collectors isolated from ground?
regards Andrew T.
Maplin mosfet problemsHide this!Advertise here!
Maplin 100W mosfet amplifier - power supply problem HBrunt Solid State 32 3rd December 2013 08:11 AM
Maplin 150w MOSFET regulation? Craig405 Solid State 59 4th March 2012 09:30 PM
Mosfet problems Harrie Nak Solid State 2 21st October 2008 08:29 PM
maplin mosfet GA28F upgrades? Gravenstede Solid State 5 17th March 2008 07:34 PM
Maplin 4-20 Trebla Tubes / Valves 14 28th January 2006 05:14 PM
