I have tried to follow the ESP P06 phono stage schematic using stripboard and have run into some problems which I feel sure are of my own making.
When it was first tested, the output volume was very low with weak treble and poor sound quality on both channels. About 5 minutes later one channel stopped working entirely, not good. I re read the article and realised I had neglected to include the 10uf decoupling capacitors to the supply rails mentioned in the text, using only the 100nf from supply pins to ground. Further head scratching revealed I had also misread my own hand writing and used 27nf caps for C1L and C1R rather than 22nf as shown. Embarrassing. I am assuming I have oscillation problems going on and wonder if the lack of decoupling is to blame, or whether I have grounding issues also. I ended up with 5 strips serving as grounds jumpered together, connected by one wire to the power supply. I had wondered whether these would be better returned with an individual wire for each strip. I would appreciate any input on this before I go for version 2 with the correct values used this time and hopefully a better outcome. John |
#2 |
Both things could possibly be the reason of oscillation.
Correct decoupling of supply pins is so important, that it is standard for OP-Amps. Improper design of PCB-layout with a less good grounding route can give problem. Of course the main reason for your oscillations is most probably those values. If you try with correct values now, I think it will work good. OPA2134 is not known for oscillations. It is a very stable op-amp.
lineup |
#3 |
Hi lineup, thanks for your comments.
I am using stripboard rather than a pcb, I need to learn Diptrace or similar but it is one thing at a time. I will order some more capacitors and try again. If nothing else I have a chance to learn from the problems. John |
#4 |
Also try to keep the physical implementation of the feedback loop as short as possible
Sometimes just cleaning the board thoroughly after all the soldering have being done could also help |
#5 |
Hi nonoise
I had the feedback loop down as small as I could, in fact everything was as compact as I could make it. I scrubbed the board in isopropyl with a toothbrush before looking for shorts etc. Maybe version 2 will be better if I learn to read my writing and buy some spectacles! Many thanks. John |
#6 |
Version 2 is built using the right values, the right opamp decoupling and more care with the grounding. It has been playing for a few hours now and all is well.
It sounds good even using an old JVC turntable I had kicking around and less than perfect vinyl. Once it gets to my mates Garrard 401 it should be splendid! Thanks for the help chaps, there has been good learning had from the project for me. John |
#7 |
Congratulations
| NE5532 or OPA2134 | wandelblu | Chip Amps | 18 | 9th June 2007 12:53 PM |
| Is there any better OP than OPA2134 | Progg70 | Solid State | 95 | 15th March 2007 07:15 PM |
| WTB: 8pcs OPA2134 | cartman | Swap Meet | 0 | 12th November 2006 07:27 AM |
| Need help with Entech 205.2 / OPA2134 | shon | Digital Source | 1 | 20th March 2005 09:21 PM |
| what to do with OPA2134? | kmj | Chip Amps | 3 | 12th January 2005 08:38 PM |
| Page generated in 0.12228 seconds (63.35% PHP - 36.65% MySQL) with 10 queries |
