diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   ec aw 250 dmb (http://www.diyaudio.com/forums/solid-state/147395-ec-aw-250-dmb.html)
haugene98 12th July 2009 05:25 PM
ec aw 250 dmb
I have the opportunity to buy a ec aw 250 dmb very cheap beacuase of a blown output transistor. I have not actually seen the amp. I just wonder if anyone in this forum have experience with this amp and know if there is anything else that can be blown beside the output transistors. Maybe it is not smart to buy it anyway.
The amp is about 12 years...
taj 12th July 2009 05:33 PM
I haven't heard of this amp, but generally speaking it's VERY LIKELY that more components are blown. Output transistors don't typically die unless they are somehow overloaded. And worse, once they die they tend to short out causing other components to die. Of course the amount of damage depends on the amp's protection circuitry.
If you're asking whether replacing the dead output transistor will fix it, probably not.
..Todd
haugene98 12th July 2009 07:45 PM
Thank you for the reply. It is a Electrocompaniet amplifier, made in Norway....
Roar Malmin 12th July 2009 09:17 PM
I have the schematics, and the parts to fix it. I`m located in Hokksund, and I`m in the book.
Roar
haugene98 13th July 2009 04:46 AM
Thank you Roar.. I`ll contact you
nigelwright7557 13th July 2009 08:33 PM
Re: ec aw 250 dmb
Sometimes the output transistors take other devices with them.
I usually pull all transistors and test them on a multimeter for hfe and shorts. While the transistors are out I check all resistor values. Check capacitors for shorts too.
Given the age of the amp then it would be wise to replace all electrolytic capacitors.
Copyright 1999-2017 diyAudio
