Old 7th July 2009, 09:41 AM   #1
tomat is offline tomat  Indonesia
Default need recommendation good sounding transistor
I plan to build AB class ss pwr amp,which can deliver 250 to 300watt each channel ,any recommendation what transistor sould i use?
thanks
cheers
K
Old 8th July 2009, 12:35 AM   #2
mj ,2sa ,2n ,a.... ,??
Old 8th July 2009, 12:40 AM   #3
uhu..hu..hu.. no one suggest me..
Old 8th July 2009, 02:40 AM   #4
EchoWars's Avatar
Find a design first...choose transistors last.
Old 8th July 2009, 02:41 AM   #5
CBS240 is offline CBS240  United States
CBS240's Avatar
Hi
IMO, it is not so much which transistor but rather the design. There are some devices that are better than others for a particular design. The output impedance will have an influence on which transistors are suitable. Cost and availability may have an influence as well. Just watch out for fakes. More info is needed for anyone to make an accurate suggestion.
All the trouble I've ever been in started out as fun......
Old 8th July 2009, 06:05 AM   #6
cbdb is offline cbdb  Canada
Its the cicuit design that has a "sound", and it will only sound its best (or work at all) if the transistors are not under specified for there specific use in the circuit. Picking the right transistors is not an easy task especialy after the input stage. Current, voltage and power limits are just the start, then theres Beta, Freq response, Beta droop, early voltage, Beta variation with Ic and Vce, packaging, cost availability and other transitor characteristics that may or may not matter depending on where they are used.
Thats the best thing about this forum, ask and some one will answer.
But to answer this question one needs more info, the circuit design.
Old 8th July 2009, 10:48 AM   #7
AndrewT is online now AndrewT  Scotland
find a design that uses three pair MJ21193/4 in the output stage.
3pair of these 250W devices will pump out 300W all day if you need it to.
regards Andrew T.
Any good sounding cd player suggestions to buy used ? gaetan8888 Digital Source 6 31st July 2007 09:14 PM
Good sounding 6V6 PP UL driver circuit? SHiFTY Tubes / Valves 20 30th April 2007 11:34 AM
good sounding professional woofers ? punk Multi-Way 14 3rd June 2006 09:43 PM
Good/Bad Sounding Chips Wynand Chip Amps 12 15th July 2005 04:36 PM
power transistor recommendation metebalci Solid State 0 12th May 2004 03:08 PM
Page generated in 0.11891 seconds (58.43% PHP - 41.57% MySQL) with 10 queries
