Old 7th July 2009, 06:48 AM   #1
Default Power down transient
I've got a McIntosh MC 2505 stereo power amp that has recently developped an issue. When it power downs it outputs a transient snap. My worry is it will damage my tweeters. I haven't given the internal components a look over yet but I don't expect to see anything because it still functions normally. If anyone has any suggestions or questions feel free to ask. I know this is hardly enough information to even think about diagnosing the situation but I have electronics skills so I can figure out most questions about the amp.
Thanks,
Cody
Old 7th July 2009, 08:53 AM   #2
h_a is offline h_a  Europe
h_a's Avatar
One possibility, especially for older amps, are aged caps, discharging at different speeds. That causes usually also turn-on thumbs.
Changing caps is anyway not a bad idea (if they're 10 years or older).
Have fun, Hannes
Old 7th July 2009, 10:24 AM   #3
Frank Berry's Avatar
It's possible that the ESR of the power supply caps has gone up with age. Replace the caps.
Frank
Old 7th July 2009, 11:57 AM   #4
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default Re: Power down transient
Thanks,
Cody
If it wasn't doing it before, it is not the caps deteriorating. The turn-off transient doesn't depend on the caps but on the particular topology.
If it worked finr before, it might be that there is a relay mute function that held off connecting the speakers until the amp stabilized. This is pretty standard in power amps.
If there is a relay system, check whether it is indeed defect, and then we need to figure out how to fix it.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 7th July 2009, 05:28 PM   #5
I figure it is probably just the capacitors (god knows which one) discharging too quickly. It has always had a slow and low level thump when it turns off but this transient is new. I opened it up today and as I expected it looks fine besides having not been opened for 40 years(it was "born" in 1971).
Also I do not believe this amp has any relay circuitry.
Thanks,
Cody
Old 8th July 2009, 02:54 AM   #6
An update you could say. I put the covers back on and did a little more investigating into what was happening. The right channel is the only channel that has developped this problem. It was hard to figure this out before because my amp is right next to my right speaker but it registers on the meters. The left meter will slowly fall while the right one is immediately nulled once I turn off the power(not to mention the snap that I hear). And the problem is intermittent...
PGA2311 power off transient breez Digital Source 6 28th July 2008 05:44 PM
Controlling transient response AdamZuf Tubes / Valves 29 6th July 2007 01:38 AM
Transient test track BWRX Everything Else 8 31st July 2006 10:15 AM
Transient Perfect reproduction Thunau Multi-Way 0 24th July 2006 01:18 AM
EBS transient response Solid Snake Multi-Way 1 1st February 2004 05:26 AM
Page generated in 0.10950 seconds (61.55% PHP - 38.45% MySQL) with 10 queries
