Old 6th July 2009, 04:56 PM   #1
Default My Cambridge Audio A5 Amplifier
I had a party on Friday and my beloved Cambridge Audio A5 Amplifier died. it got very hot so i turned it off and left it, now it wont turn on at all. i opened it up checked the fuses they all seem to be fine apart from a few, which have a squiggly shaped wire? however this could be what it should look like i have no idea. please help your sincerely Holden Wright
Old 6th July 2009, 05:11 PM   #2
sakis is online now sakis  Greece
sakis's Avatar
Default twice so far
hapent to costumers of mine that actually the amp was ok the outputs and power supply was ok but the transformer was gone
you have to check carefully everything starting very carefully from mains till the end
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 6th July 2009, 06:00 PM   #3
jaycee is offline jaycee  United Kingdom
Cambridge amps are not party amps unfortunately. They have poor protection circuitry and inadequate heatsinking.
If there is no signs of life at all then I concur with Sakis, the transformer has probably packed in.
The official service agent for these amps in the UK is Richer Sounds. You may find they charge more than it is worth, however...
Old 6th July 2009, 06:11 PM   #4
sakis's Avatar
Default right on jay cee !!!!
yeah !!!!! i had the same exact problem with our local distributor ....he asked i thing 4-5 times the cost of a costum made trafo
i got it winded new in athens for peanuts .... still working like hell after 4 years of use and abuse ha ha ha
Old 6th July 2009, 08:07 PM   #5
that makes sence, that was my fear about richer sounds i have no money
How would i go about testing if it is the transformer?
And where would be the best place to buy a new one?
Old 6th July 2009, 08:49 PM   #6
Measure continiuity between the pins of the mains plug with the power switch on. If you don't get a reading, the transformer's shot.
If you do, then you should check the secondary side output with a multimeter set on AC. Power it up and see if there is any output.
Old 6th July 2009, 09:30 PM   #7
Puffin is offline Puffin  United Kingdom
A new transformer will be between £12 - £15 from Rapid Electronics or similar. However if you have no experience of electronics then you may be safer to get some who does know to replace it. But you need to test it first or you may waste your money. It could be something else.
Pity I am not nearer Brighton, I would have offered.
Old 6th July 2009, 10:55 PM   #8
Likewise. It is not a fit and forget part. Without some good understanding of electronics repair, you're just risking causing more damage.
For example, you might replace the transformer, only to find the output transistors are also shot.
Old 6th July 2009, 11:08 PM   #9
I did a bit electronic at gsce, wasn't bad with the old soldiering iron. thank you for all your help x
Old 7th July 2009, 07:28 AM   #10
sakis's Avatar
Default keep in mind
that this a guess .... my guess ...and jaycee thinks that is right ... it could be something else .... so dont rush in to a trafo before you are sure about what is going on ....
Cambridge Audio A5 Amplifier Repair cahillj Solid State 1 20th April 2009 06:07 PM
Cambridge audio A5 integrated amplifier schematic cahillj Solid State 1 11th April 2009 01:54 AM
Cambridge Audio A3i Integrated Amplifier audio44 Solid State 5 26th August 2008 03:42 PM
Cambridge Audio 640C No audio output PLEASE HELP! Kajman Digital Source 3 10th December 2007 09:45 AM
cambridge audio a3 i amplifier for sale homertooties Swap Meet 2 12th November 2006 06:13 PM
Page generated in 0.24811 seconds (35.56% PHP - 64.44% MySQL) with 11 queries
