18 volts on sub preamp
hi everybody in this forum. I was wondering if someone could help me with my problem.I have a STK 300watt powered 15 " PA sub that the preamp transistors have blown up. I was about to replace them and checked the voltage from the power amp side to the preamp and it was 18 volts. is this right? The transformer is a 40-40 volts. The power amp transistors are 2 mjl21193 and 2 mjl21194.
