Old 6th July 2009, 01:38 AM   #1
mikje is offline mikje  United States
Soakin' up the Sound!
mikje's Avatar
Default Marantz 2235B Tuner Issue???
I have a 2235B and everything works fine except the tuner. It picks up a few stations, but misses many (We have less than a dozen FM stations from which to choose).
-I know I can get stations; I do on other receivers.
-The stations that do come in are very weak; I have to turn up the volume quite a bit to hear them.
-The tuning meter, signal strength meter, and the stereo light never budge, even when I manage to pull in a station.
-When I do have a station pulled in and I push the FM Dolby 25us button, the station gets muted to the point I can't hear it.
-The FM muting button has no effect; I don't hear the usual "rushing" sound with FM muting not selected.
-I get no AM reception at all.
-I have de-ox'ed and faderlubed all my switches more than once.
Any input on what the issue might be? I don't have an o'scope, so if it's an alignment issue, I'll have to either take it to someone or live with it.
Thanks in advance for any suggestions or input.
Mike
Marantz PM8003 amp, Squeezebox Touch, DIY Krystals
Jolida SJ502B, Mark Audio Alpair 10.2s
Old 6th July 2009, 01:45 AM   #2
I don't know how integrated the tuner circuits are, but it could be a bad transistor that kills the gain, a bad coupling cap, a cracked trace (signal still gets across the capacitance of the bread, or about fifty other things. Without a scope and a schematic I wouldn't know where to start. That's the only good way to troubleshoot this. Whatever you do, don't go turning any of the alignment adjustments!
I used to be an audiophool like you but then I took an arrow to the knee.
Old 6th July 2009, 03:10 AM   #3
infinia is offline infinia  United States
infinia's Avatar
This might be the key somes they share common circuits. but sounds like the RF or IF tuned circuits have drifted off a bit.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 6th July 2009, 10:18 AM   #4
sakis is offline sakis  Greece
sakis's Avatar
Default a 2235 unit
is probably 25-30 years old ..... similar units like 2245 and more come in to my shop for repiar or upgrade
none of the existing electrolytics inside was even close to the original value ...
you may recap the all unit but simply do not touch any trimmer especially in the tuner area
this will make everything back to normal
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 6th July 2009, 01:21 PM   #5
infinia's Avatar
Yes the AGC detector is usually common to both AM and FM, look there first, could be a leaky small bypass electo. If it is loss of gain due to drifted tuning, then you would most likely hear distorted audio.
sakis. I like your trouble shooting style, works best without schematic or equipment
Old 6th July 2009, 01:28 PM   #6
sakis's Avatar
Default we meet infinia
yet again on a repair issue
but it seems that we might share the same feelings about greek wine but not about repairs
i wasnt talking about "a" capacitor ....i was talking about ALL capacitors ...
22XX family i repaired i think 4 pcs this year none of them had a proper electrolytic inside
only one of them that i repaired i replace all of them inside and since tuner seemed to work properly i left all electros there as was ...
costumer takes the amp very happy with it ....operate it for a month and then return it with the problem of 1KHZ sound to all inputs ....
the electros i didnt change in the tuner area produced some oscilation that was audible in the all amp ....replaced them to and all is fine ...
Old 6th July 2009, 01:31 PM   #7
infinia's Avatar
Default Re: Marantz 2235B Tuner Issue???
OK Sounds like the AGC detector. ( but it is part of a control loop )
sakis here we call that shotgun trouble-shooting
Old 6th July 2009, 01:36 PM   #8
mikje's Avatar
Thanks for all the input.
How do I identify the AGC detector?
I have done some recapping, but not on the tuner section.
Thanks,
Mike
Old 6th July 2009, 01:41 PM   #9
infinia's Avatar
Really need a schematic or picture
What mods or repairs have you made so far.
Old 6th July 2009, 01:45 PM   #10
mikje's Avatar
Infinia,
I recapped and replaced the diodes and transistors on the PS board.
Mike
marantz 1060 issue pezza89 Solid State 3 29th June 2011 01:02 AM
Marantz 2235B running hot mikje Solid State 12 9th March 2009 07:20 AM
marantz 1060 issue pezza89 Solid State 3 1st June 2008 10:03 AM
marantz 1180dc issue pezza89 Solid State 6 4th December 2007 07:14 AM
Marantz 104 tuner pezza89 Swap Meet 0 10th November 2007 10:37 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
