Old 4th July 2009, 11:44 PM   #1
joeyuk is offline joeyuk  United Kingdom
Default whats the besy way of testing Sanken LEXAM SAPM01 transistors??.
been given a e faulty pionner surround amplifier
theres a problem keeps comming up with error was told power output stage is damaged.
i have had a look at the power transistors question is the transistors are Sanken LEXAM SAPM01 audio transistors.
i have noticed they are not like normal 3 pin power transistors which you can test with a dmm on diode function for shorts but these have 5 legs how do i test these as not come across these type before?
can someone please advize.
thanks
Old 5th July 2009, 01:52 AM   #2
jackinnj's Avatar
They are diode incorporated MOSFET's -- you can get replacements form Profusion in the UK. Here's the datasheet;
http://www.profusionplc.com/static/i...ts/sapm01n.pdf
Old 5th July 2009, 09:44 AM   #3
thanks any ideas which number pins i need to test ? as theres 5 on this transistor.
Old 5th July 2009, 01:17 PM   #4
jackinnj's Avatar
If I have what appears to be a blown MOSFET I disconnect the source, connect the gate and drain together and apply a current controlled (200mA, 500mA is fine) 12V source to the drain-gate junction, measure the voltage from the DG junction to S -- these flavor of MOSFET's turn on at between 3 and 4 volts, so you should get a reading in the vicinity of 4V if they are working.
I have never blown out the temperature sensing diode in Sanken's bipolar transistors, but it is important that the current flowing through them is at the level specified by the company, elsewise they will experience thermal runaway. In this case it would appear that you should lift pin 4 of the P-channel device, measure the resistance from pin 4 to 5. Reconnect to the circuit and measure the voltage across the pin 4 and 5 -- which will give you the forward current (should be 3mA).
I can't find these transistors at the usual 2 suspects for Sanken -- ProfusionPLC and Allegro.
Old 5th July 2009, 02:45 PM   #5
thanks jackinnj
is there a simple was of testing them with a dmm?
as thats how i uselly test transistors but im a bit puzzled with these concidering they have 5 legs.
Old 5th July 2009, 03:23 PM   #6
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally posted by jackinnj
can't find these
Looks like the duo is heading to become a different kind of Legend in it's own time.
Looks like Sponge Bob has killed another thread.
Old 6th July 2009, 02:04 PM   #7
any ideas how i can test these on my digital multimeter guys?
do i test same as normal 3 pin power transistors? as the 5 leg type in throwing me.
im getting "amp error" so wanted to check power output transistors.
Old 6th July 2009, 02:59 PM   #8
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
One obvious test is for shorts between any two pins. If you're lucky ( ) that will be the case (disconnect the pins from the board before doing this).
Also, the build-in emitter resistor may be open-circuited, this happens often with the MOSFET itself still being OK. If that is the case you can put in an external emitter resistor and you're good to go.
Other than that I don't know of a simple way to test MOSFETs with a multimeter.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 6th July 2009, 04:56 PM   #9
ok just a update guys.
i was getting "amp error" soon as i switch on amp, checked the sapm01 they all measure the same so think they are ok.
i then removed AWX8411 small board which is connected to main transformer and the amplifier come on as normal ??
all i can find about the AWX8411 small curcuit is its a VH TR ASSY, not sure function of this small board.
looked at the 2 transistors checked with diode function and seem ok?
heres a few pics of the small board and also pinout where it connects on transformer.
the small curcuit
rear of curcuit
pinout connection off transformer
anyone any ideas why is comming on when this board is dissonnected and i get amp error when it is connected?
Old 6th July 2009, 11:03 PM   #10
anyone any ideas what the VH TR ASSY circuit is used for ?
Sanken SAP15 transistors lohk Solid State 53 10th April 2010 09:41 AM
Sanken SAP16 transistors? bbakota2000 Parts 9 1st November 2005 11:49 AM
sanken transistors picchiatello Parts 1 22nd March 2005 02:11 PM
Sanken LEXAM SAPM01 audio transistors peranders Parts 7 16th October 2003 08:04 PM
Where to buy Sanken and Toshiba transistors weinstro Solid State 5 8th October 2003 09:58 PM
Page generated in 0.14703 seconds (69.94% PHP - 30.06% MySQL) with 10 queries
