I have a question about substituting OPA627s in place of OPA2134s. I am thinking of trying 627s as input buffers in one of my amps versus the stock 2134s. I've found a company that supplies a pair of Burr Brown 627s mounted in an adapter that will drop in, in place of the 2134s. Attached is part of the amp schematic with the 2134s. Do I need to make any parts changes to the circuit to accommodate the 627s ?
#2 |
It should be fine. The 627 is probably more sensitive to PS decoupling and you will get optimum sound with some more substantial decoupling caps in addition to the 0.1uF, maybe as high as 100uF. And preferably close to the pins.
#3 |
diyAudio Moderator Emeritus
By any means put an extra 100 nF MKT directly between + and - pins when using 627's ! Wima MKS2 with 5 mm pitch is just fine for this task.
Analog_sa is right about C105 and C106. They need to be replaced for bigger values preferably Panasonic FC 10 uF to 47 uF. Possibly 100 uF would not hurt either. You could parallel them to the originals but replacing them for superior stuff is the best solution.
It's only audio |
#4 |
Guys, great replies. Thank you. BTW, what is Panasonic "FC" ? Film cap / metallized polyester film cap ?
#5 |
Electrons are yellow and more is better!
Worth noticing is that OPA627 consumes more power than 2134, 14-15 mA vs. 8 mA
/Per-Anders (my first name) or P-A as my friends call me |
#6 | |
| OPA2134 Oscillating? | john blackburn | Solid State | 6 | 19th July 2009 01:45 PM |
| My result of opa2134 and opa627 comparison | HiFiNutNut | Digital Source | 74 | 29th April 2008 10:47 PM |
| Is there any better OP than OPA2134 | Progg70 | Solid State | 95 | 15th March 2007 07:15 PM |
| WTB: 8pcs OPA2134 | cartman | Swap Meet | 0 | 12th November 2006 07:27 AM |
| what to do with OPA2134? | kmj | Chip Amps | 3 | 12th January 2005 08:38 PM |
| Page generated in 0.09887 seconds (64.14% PHP - 35.86% MySQL) with 11 queries |
