TIME OUT!
I am now totally confused by something a bit odd.
This morning, fiddling with the "scrap" 3020B pcb I have here I noticed that I missed something on my 3020A's board. (follow this thread for full explination: http://www.diyaudio.com/forums/showthread.php?s=&threadid=144285&perpage=25&pagenumber=1)
I had noticed that the previous owner's DIY efforts did not only remove the fuse holder section but also severed a supply line to a small network connected to the output of the pre-amp section. This supply line feeds a very odd network that in turn feed the FET's [Q509 & Q510] (I think they act as a buffer stage) on the pre-amp output.
When I restored the connection the amp behaved slightly different but not in a good way. When powering on there is now a violent "zonk-buzzzz-hummmzzzz" that stays a while until it fades away.
The oddity is that the amp functioned just fine without this connection.
See attachment. Can anybody explain what this circuit does?
TIA
TIA
analog_sa said:Found the circuit. It is indeed a mute/delay switch. Short-circuiting will deliver a slightly better sound which is probably what the previous owner did.
But now I want to pose the following question: What does it "mute/delay"? There is a terrable sound when the unit is switched on and the "plop!" sound remains when the amp is turned off.
What do you mean by "short-circuiting"? The previous owner didnt disconnect it... he probably never saw that he has cut it off. Should I connect the AC feed line to ground?
It shorts the preamp output to ground, which mutes the sound. The nasty noise is probably coming from the preamp circuit which takes some time to stabilise on power up. The circuit would've muted for about a second on power up.
GlidingDutchman said:Should I connect the AC feed line to ground?
NO - if you do that, you will blow up the transformer. If it's been removed, leave it as it is.
A better solution would be to add a DC Protect circuit between the output of the amp and the speaker terminals, which has a power on delay. It doesn't look like theres enough room in the case for that though.
Difficult to say who did what and when. It appears that the mute circuit was working properly before the "repair", so something is not right.
My suspicion as well.
- Oddity with NAD 3020A
