Old 15th November 2009, 02:51 PM   #51
danfo098's Avatar
To get the quiescent current I measure the voltage drop over the 0R1 emitter resistors (both at 3.7 mV with R36=0R). To get the total current I've measured the current coming out/in of/to the +-50 V rails with my multimeter in series and the bench supplies also confirms 120 mA.
The bench supplies show 25 V in the video but it's a 2x0-30 V supply with a button to series connect both supplies so it's 2x25 V per supply.
I haven't done any more measurements. The card is so compact and packet with components that it's hard to get access without accidentally shorting something.
I forgot to include the zener current for the cascode biasing so the total should be 81 mA.
Old 15th November 2009, 11:16 PM   #52
danfo098's Avatar
I've done some further measurements on the total current consumption and now my multimeter shows 90 mA on both rails (it's a velleman DVM92, I really need to get a better one). I also revisited the simulation and it says 94 mA on the positive rail and 92 mA on the negative rail (with 39 mA quiescent current) so now it seems that all the currents do add up.
However the bench supply still shows 120 mA but I don't trust it.
The dc offset is 2 mV according to the velleman, (simulator says 17 mV).
I've also measured the voltage drop over the 22R filter resistors ~0.9 V and that checks out with the simulator.
Now I need to get a scope and a signal generator to.
Old 16th November 2009, 05:13 AM   #53
Congratulations on successful power up! The best sounding amp is always the one you just built yourself.
What are you using for R47, R48 (the output emitter resistors)? The package looks impossibly small.
Old 16th November 2009, 07:39 AM   #54
danfo098's Avatar
Thank you.
The output emitter resistors are caddock MP930 0R1 30 W, and they are mounted on the heatsink.
http://www.caddock.com/Online_catalo...000_Series.pdf
Old 16th November 2009, 09:51 PM   #55
Interesting! thanks for the link.
Old 17th November 2009, 01:07 AM   #56
danfo098's Avatar
Here are some high resolution pictures as promised.
SimSym Amplifier High Res Pictures
Need comments on amp design mightydub Solid State 28 24th December 2008 02:01 AM
My first amp design - comments blueskynis Solid State 36 26th March 2008 04:38 PM
need comments on amp design metebalci Tubes / Valves 0 10th September 2006 09:03 PM
Comments on TL design, pls Jorge Multi-Way 2 9th June 2005 04:05 PM
Comments on this design? G Tubes / Valves 0 16th October 2003 06:09 PM
Page generated in 0.09126 seconds (74.29% PHP - 25.71% MySQL) with 11 queries
