Old 28th June 2009, 01:37 PM   #1
flacer is offline flacer  Malaysia
flacer's Avatar
Default HPPA Amplifier not working
I just finish connecting this amp
But when i switch on the power.. the whole amp not stable.. input voltage oscillating
And the resistor 33ohm(shown in picture) is very hot and turning black..and the voltage drop across this resistor is 15V i think
The input stage current mirror side i am using 9100 ohm
The other adjustable resistor i put in the middle side.
The output voltage is 43V...omg
No shot circuit.... i checked
I did simulate this amp in LTspice.. but in real circuit is not working...
I'm using 45V as main supply
who can help me up?
thanks
Old 28th June 2009, 05:59 PM   #2
jaycee is offline jaycee  United Kingdom
is the 1K trim pot in the BD139 set to full resistance?
Personally I think this circuit is rubbish.
Old 28th June 2009, 06:12 PM   #3
flacer's Avatar
I'm using 2k... it is in the middle position... should be 1k
This circuit designed by Bert Molenkamp should be no problem..
I know someone is building this amp before... they are working
Why do you say is rubbish?
regard!
-flacer
Old 28th June 2009, 06:49 PM   #4
mjf is offline mjf  Austria
hello.
perhaps you have built in a transistor (or diode) reverted or connected wrong?
greetings............
Old 28th June 2009, 07:00 PM   #5
flacer's Avatar
Originally posted by mjf
hello.
Hi~
Previously the BC556 i connected wrong ( i inverse the collector and emitter).. but the circuit nothing burning.. and not working as well
After i check the datasheet and reconnect it... the 33ohms resistor start burning
6 output transistors are fused... and connected follow datasheet
How to know a transistor is faulty? I'm going to check all the transistors
Note: instead BD791 i am using BD139 .... BD792 i am using BD140
-flacer
Old 28th June 2009, 08:00 PM   #6
hello.
bc 556 have max. uce = 60v
you can check these parts with the hfe - tester on a multimeter.i would begin with this................
greetings........
Old 29th June 2009, 03:46 AM   #7
flacer's Avatar
hello.
greetings........
All transistor are ok...
I'm not using the voltage regulator now.. and change the adjustable resistor to 15k ohm
the output voltage now around 23V
the 33 ohm resistor i changed into new one still burning (voltage drop 15V)
next what should i check?
-flacer
Old 29th June 2009, 04:20 AM   #8
flacer's Avatar
wait....
i think the BC556 at current mirror there is burn
i try to change first
-flacer
Old 29th June 2009, 05:16 AM   #9
flacer's Avatar
Just now changed the BC556 at current mirror and 2 X BD139 VAS
the result still same... 33 ohm resistor burning ... but voltage drop across the 33 ohm resistor increased to 20 volt...
i guest the problem is at the VAS...but not sure
any suggestion?
-flacer
Old 29th June 2009, 08:37 AM   #10
only the 556?...........lucky man........now it works.
greetings.................
HPPA amplifier (Bert Molenkamp) flacer Solid State 3 12th May 2009 05:22 PM
FS: a/d/s Ph15 amplifier - 50% working - $50 owdi Swap Meet 4 28th September 2007 04:24 PM
**** amplifier for party is not working! Destroyer OS. Solid State 3 31st October 2006 08:26 PM
no working amplifier Diogo Solid State 31 31st October 2002 05:58 AM
Page generated in 0.15152 seconds (55.11% PHP - 44.89% MySQL) with 11 queries
