| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
Hi at all.
I am trying to make this amplifier. I channel is under test, but I have a problem that can't explain. Averything works fine, it's also playng in this moment and I have to sey that sound seems much better than I expected, but there is a big problem . With the scope I have seen the sin wave at 1 Khz, to be clipped at +- 11V. Rail ar +/- 41 Vcc. Could someone give me an idea of why this happens? Thanks at all
Michele |
#2 |
Did it Himself
Probably because of R1 and C1.
And yes, there are capacitors in the circuit. One is even employed to form the dreaded bootstrap on the voltage gain stage. Get over it. -Burning Amplifier #2, Nelson Pass www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
Hi Richie
I have tryied with C1 off, (100% global feedback) but it is just the same. Regards
Michele |
#4 |
If you look at the local NFB loop around the LM3886, how high is the DC gain? How high is your DC offset?
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#5 |
I don't know what you mean. The local gain is 26 db that is the same of the global. The offset at the exit is about 30 mV.
Michele |
#6 |
hello.
perhaps you can use this basic schematic.......... greetings............ |
#7 |
Thanks mjf,
but your schematic is full nfb, while mine have only DC feedback from the load and it's dc coupled.
Michele |
#8 | |
For the local feedback around the LM3886 the gain is R24+1/(C1*2*PI*f)+R17/R17. 1/(C1*2*PI*f) becomes infinity for DC, which makes the DC gain also infinity. Only thanks to R1 you don't get DC with nearly rail voltage at the output. So the local DC gain is infinity and the global DC gain = global AC gain is 22. What does that mean? For DC only the global feedback is relevant. For AC you force the voltage differential between the LM3886's output pin and the amplifier output to be 1/22 of the output voltage. Is that stable across the entire voltage range of the amplifier from 0 to full output swing? E. g. for an output swing of 22 V there would be 1 V across R1 and either across R21+M2+R5 or across (R13+R3+R7||Q1||C4)+R6+M1+R4. For an output swing of 11 V there would only be 0,5 V. For an output swing of 5,5 V there would be 0,25 V. Can that preform well?
#9 |
Hi PB
For 22 V output swing, the only place where I have 1 Volt is across R17-R24. In all of the other places you mentioned except R1 I have 22V shifted of 3,8V of the bias (+26 -18). It is like if the 3886 is working in it's internal with an offst of 21V, that is the offset that the LTSpice gives to me if I take off R1. Regards
Michele |
#10 |
No, of course you won't get 1 V. That is what should be there, if the feedback loop would work. In a real circuit the IRFPs will win the battle and force a different voltage across R1, thus rendering the feedback loop useless.
Which model do you use for the LM3886? I simulated it with teemuk's and as long as I don't short C1, the output shows ~40V DC as predicted in my first post. With C1 shorted, there is about 220 mV DC offset. An additional blocking cap in series with R17 brings that down to ~60 mV. I don't see any way to make your feedback scheme work. You should try mjf's schematic.
| Thread Tools | |
| Tda2030a driving mosfet | jazzman06 | Chip Amps | 9 | 16th July 2009 08:48 AM |
| hide side mosfet driving | jegandren | Power Supplies | 14 | 2nd November 2008 07:16 PM |
| MOSFET driving with transformer | Danko | Power Supplies | 22 | 30th May 2007 11:19 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 11:24 AM |
| Driving a MOSFET power follower | RichardJones | Pass Labs | 19 | 22nd July 2002 03:02 PM |
| Page generated in 0.18888688 seconds (83.75% PHP - 16.25% MySQL) with 11 queries |
