Old 26th June 2009, 08:35 AM   #11
pro is offline pro  Italy
pro's Avatar
Hi PB
I solved the problem of the 12V.
It's the scope that is not right.
Yesterday night after many test, I have tryed to misure my gainclone that works alone with the same PS, and guess? It clipped at the same +/-12V. So, I have attached the probe to the calibration point of the scope, and for a 1 Vp/p I have read about 350mV p/p.
I have the same your simulation, but in the real life, the DC offset starts ad -100 mV with cold amp and then rises at about 750mV after warm-up. Tonight I try to put a 220u cap in series R17 as you seid and see if offset goes down.
Michele
Old 26th June 2009, 02:15 PM   #12
Khron is offline Khron  Romania
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
pro , i've sent you an email yesterday (to avoid off-topic-ing here)
Old 28th June 2009, 10:53 AM   #13
pro's Avatar
The cap in series to R17 doesn't have any effect. There is a big difference between the simulator and real life.
The DC offset starts at 20 mV in first 10 minutes, then rises to 400 mV when the heatsink is warm( maybe it's too small), that i thing due the VBE multipler that is a bit overkill. I'm gonna try to slow down it with en emitter resistor on the BD139.
Anyway, the circuit seems to work very well. The output impedence mesured, is about 1/2 hom, for e DF of 15 at 20Hz and 1Khz on 8 hom. (remember that there is no glbal NFB, just DC.
Next step, i'll try a bootstrap for mosfet drain, bigger heatsink and some protections for mosfet (I have already burned two pairs of them)
Michele
Old 28th June 2009, 11:10 AM   #14
where is the Vbe multiplier (bd139) mounted?
regards Andrew T.
Old 28th June 2009, 11:18 AM   #15
pro's Avatar
The photo is of the version without VBE. Now it's between the mosfet. That one, had problems of temperature, due the 33p that was making oscillate the 3886. Without it, no oscillations.
Michele
Old 28th June 2009, 11:34 AM   #16
what's the point in posting the wrong pic with a description?
To confuse us?
Do you want our help?
Always show/fit Vgs max Zeners.
These if reduced to match the Id vs Vds curves in the datasheet can be effective current limiters.
regards Andrew T.
Old 28th June 2009, 11:47 AM   #17
pro's Avatar
Sorry Andrew I didn't have a new one. Just made it and upgraded the post.
Can you show a small schematic for zener or a link where to find it? Thank you.
Michele
Old 28th June 2009, 12:03 PM   #18
read Pass & ESP and others.
The Zeners are often shown in power FET datasheets.
regards Andrew T.
Old 28th June 2009, 12:21 PM   #19
pro's Avatar
Thank you Andrew. I'll give a look.
Michele
Tda2030a driving mosfet jazzman06 Chip Amps 9 16th July 2009 08:48 AM
hide side mosfet driving jegandren Power Supplies 14 2nd November 2008 07:16 PM
MOSFET driving with transformer Danko Power Supplies 22 30th May 2007 11:19 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 11:24 AM
Driving a MOSFET power follower RichardJones Pass Labs 19 22nd July 2002 03:02 PM
Page generated in 0.10752 seconds (85.34% PHP - 14.66% MySQL) with 11 queries
