Old 24th June 2009, 05:39 PM   #1
jazzman06's Avatar
Send a message via ICQ to jazzman06
Default need advice - how to test FETs
hi ,everyone can u help me please !
i have 2 pairs of irfp9240/irfp240 how can i test them?
in other words how can i test FET devices
thank a lot for requesting!
best regards MAXIM
Old 24th June 2009, 10:42 PM   #2
nigelwright7557's Avatar
I would build a small circuit to test them in.
If your worried the FET's are blown then they usually go short between source and drain.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 24th June 2009, 11:18 PM   #3
Normal method is to make use of the fact that Mosfets will hold a gate charge and thus stay turned on without anything connected to the gate.
Following is for N channel FETs, reverse for P channel
Using a multimeter on diode setting, first connect the common (black) lead to the source and the red to the gate. There should be no continuity. Then move the red lead to the drain and you should read a short circuit or close to because the device should be turned hard on.
Then reverse the multimeter leads and connect the black to the gate and the red to the source, this will remove the gate charge and turn the device off. Go back to red on drain and black on source and verify that there is no longer continuity.
You need to make sure you don't touch any of the legs other than with the multimeter because even stray electric fields conducted through your body can be enough to turn mosfets on.
Old 25th June 2009, 05:22 AM   #4
jazzman06's Avatar
thanks a lot for advices and for request !!!
i have test them and every thing it's OK with them!
nigelwright7557- told to build a small circuit to test them ,what kind of circuit you propose to build?
P.S.
if i have turned on Fet device an after i'll introduce it in schematics can i damage to it?
best regards MAXIM
Beginner's test equip for speaker design. Advice? OzMikeH Multi-Way 20 1st July 2009 01:15 PM
Adcom 555 II advice - repair? test? CBRworm Solid State 15 26th November 2008 07:03 PM
Is there any test cd to test jitter using a scope ? gaetan8888 Digital Source 4 10th August 2007 09:24 AM
F.S. 2SK389BL X 25 and other J-Fets John Hinson Swap Meet 2 12th March 2006 01:28 AM
Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice moving_electron Chip Amps 0 16th February 2005 12:37 AM
Page generated in 0.08594 seconds (64.89% PHP - 35.11% MySQL) with 10 queries
