Old 26th September 2009, 11:48 PM   #11
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally Posted by argonrepublic View Post
Along those same lines. What can I install in series to attenuate HK-770 without signal degradation?
What mods will clean it up?
probably plain voltage divider :
100K in line with signal , then 100K shunted to gnd
you'll have 6db attenuation
for mods - read here :
Manu's HK Tower & ZM's Silver Turm
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 27th September 2009, 02:26 AM   #12
mp9 is offline mp9
i think my hk 880 vxi may have a 100k volume pot because the print on it
reads 00202 - 100K (?) x2 , i can't make out what the (?) is but it's a smaller
text. i'll try again when i find the magnifying glass.
Old 27th September 2009, 07:54 AM   #13
Zen Mod's Avatar
can you measure resistance between to outer pins of pot?
Old 27th September 2009, 06:24 PM   #14
mp9 is offline mp9
i tried setting on kΩ and Ω, but didn't get a reading, it's mounted to a board along with a loudness switch which i plan on removing.
newbee question, was i supposed to do it with the power on and or did i use the wrong setting on my multi meter (it has: VDC VAC OHMS Ω with, >| -)))) (audio) symbols i don't understand, CAP,TEMP,FREQ%duty, µA, mA and A ac/dc)?
Old 27th September 2009, 06:33 PM   #15
Zen Mod's Avatar
turn bloody thing off , and pull AC cord from wall ; you're risking death of you ,of amp , or both .
put multimeter in 200K range and try .
Old 28th September 2009, 12:18 AM   #16
mp9 is offline mp9
touching the the first and third wire of one of the (2), stereo wires from the innards to the board the volume pot is mounted on; 63.1 set @ k Ω .OL and 32.23 @ k Ω O.L for what ever reason it jumps around allot.
when i touch the two outer solder points of four located directly under the volume pot i get 12.50 @ O.L k Ω and 32.86 @ Ω from the first two solder points.
Old 2nd October 2009, 11:00 PM   #17
Default attenuation HK 770
I reduce my output digitally by 8db, my decibels are nice, a comfortable volume but I lose dynamics and punch. Wondering if I should use a russound voulume control or if I can simply put a couple of high quality resistor in series on speaker cables. Should I attenuate the line level instead? Output is -10dbv
Old 7th November 2009, 04:45 AM   #18
gain-wire's Avatar
well, you could convert both inputs (RCA) to SMA or BNC type connections install a fixed dB attenuator (few $), and have again SMa or BNC jacks to RCA...
a bit overkill, but those attenuators are made for RF and...
nevermind, it's 50ohms impedance, won't be good for your inputs... or outputs.
I gotta ask though, do you really think you'll hear the degradation of an added resistor in the signal path? I mean, come on!
I'd do what Zen Mod suggested in his last post.
Trans-directional-servo-logamp non-zerocrossing autogain compressing thingamajig
Harman Kardon AVR 10 halloweenguy Everything Else 6 1st February 2010 05:52 PM
For Sale Harman Kardon T60 Turntable / Harman Kardon Cd491 Cassette Deck electric blue Swap Meet 1 25th August 2006 11:36 PM
Harman-Kardon PM 665 sangram Solid State 1 17th May 2006 06:32 AM
Harman Kardon amp Ilianh Solid State 10 26th December 2005 03:27 PM
Harman Kardon amp RancidAltoid Solid State 0 10th February 2005 12:28 AM
Page generated in 0.13515 seconds (72.20% PHP - 27.80% MySQL) with 10 queries
