transistor placement on a heatsink
Old 3rd May 2003, 07:43 AM   #21
sajti is offline sajti  Hungary
Huh, it's note easy to explain the pictures by words
I saw Your photo, but this is absolutely different. If You put Your MOSFETs, as I explain, there should be longer distances between them.
I will scan the pictures, and I will show it.
Why they recommend that type of location? That configuration gives the most equal temperature along the heatsink
Sajti
Old 3rd May 2003, 03:02 PM   #22
joensd is offline joensd  Germany
If you examine quality car audio amplifiers, their
transistor placement is not in the center, if any
thing, it's located on the the edge of the pcb,
but quality car amplifiers are pretty robust and
take major abuse, plus ambient temperatures
due to climate pre-heat the fins, in any case,
these abnormal placement of transistors don't
seem to bother these amplifiers, even kilowatt
ones
The placement of the transistors is probably due to simpler manufacturing in car amplifiers.
I always have to laugh about the heatsinks in car amplifiers anyway. 600W output and just a piece of metal around.
A buddy from mine used to service car amps the whole day.
The wooden tables they were doing the test procedures on were dark brown in those areas the amps were lying on.
I think they were far beyond from 25degress above ambient
If you´d need the whole power from them permanently the manufactures wouldn´t sell one fxxxing amp due to burned out cars.
Jens
Old 3rd May 2003, 04:23 PM   #23
thylantyr is offline thylantyr  United States
Yeah, that seem to be the trend,
make a cute chassis with no fins.
Sounds like someone is trying
to save money... hehe
There are good amplifiers on the
market or even older designs that
have some heavy heatsinks with
fins that work great. All the
class D car amplifiers require
less heatsinking too.
Old 5th May 2003, 09:25 AM   #24
Post The pictures I promised
I hope they are no too much. The last one contains some information about the heatsink installation
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Sajti
transistor placement on a heatsinkHide this!Advertise here!
Mica in Heatsink TO3 power transistor or no ? aldovan Solid State 2 6th June 2008 03:39 AM
Bi-Amp / Leach / Ops Transistor Heatsink Arrangement ptah Solid State 9 11th September 2007 03:17 PM
isolating power transistor from heatsink Wagener Solid State 10 23rd May 2004 09:57 PM
Help - Mounting transistor to heatsink vsr123 Pass Labs 10 17th April 2003 11:43 AM
Vertical positioning of transistor on heatsink Eric Pass Labs 2 4th December 2002 03:14 PM
