Old 18th June 2009, 05:40 PM   #1
Elvee is offline Elvee  Belgium
Default Repair this S.E. to diff converter
I am trying to find the correct version of this circuit (fig1):
http://www.edn.com/article/CA6339252.html
The circuit shown doesn't work properly, and it is easy to understand why: there is no way the circuit can reference itself to a ground, which means the common mode and differential voltages are interdependent.
The circuit hides this fact behind a uselessly convoluted feedback scheme, that can be simplified to the equivalent shown in the attached pic:
It is now obvious that V4, the supposedly common mode voltage, cannot influence Q+.
I know the proper version exists, with resistors arranged somewhat differently, and both voltages referenced to the ground, but I am unable to find it, all application notes seem to show either this version, or the version having simple +1 and -1 gain paths, which I don't want. I would like the version with mutual cross feedback between the amps.
Old 19th June 2009, 06:19 AM   #2
heres one i almost prepaired earlier, the resistors R2 = 4k7, resistors R1 = 10k for 6db gain 15k for 10db gain, connect 2 resistors across the o\p and adj to a null at mid point (around 1k 1%) at 1khz
Old 19th June 2009, 09:10 AM   #3
Thanks for the schematic, it begins to look like what I am looking for.
It is not yet exactly right though: the output is AC coupled, and there is no specific input allowing the common mode output level to be set.
This circuit more or less emulates a floating transformer winding.
I am looking for the equivalent of a center-tapped winding, having its center tap set at a definite level.
Thanks anyway
Old 19th June 2009, 09:50 AM   #4
GK is offline GK  Australia
Sounds to me like you may be thinking about a fully differential opamp:
http://focus.ti.com/lit/an/sloa099/sloa099.pdf
Old 19th June 2009, 10:19 AM   #5
Not exactly. I want to emulate one (having a common mode pin) using two regular opamps.
Old 19th June 2009, 01:01 PM   #6
the o\p centre point will be 0v ?, i dont know what you are looking for
Old 19th June 2009, 01:13 PM   #7
theAnonymous1's Avatar
What's the motivation to emulate?
TI's THS4130 and OPA1632 are excellent all-in-one solutions.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 19th June 2009, 05:25 PM   #8
The centre point will be some arbitrary, non-zero voltage
They are indeed, and to such an extent they represent a massive overkill for this application.
The circuit is not in the signal path, and takes care of near-DC servoing signals, and a 324 is already extravagantly overcapable in this case.
Old 19th June 2009, 05:57 PM   #9
But, if you had either of those IC's would you be interested in using them? If so, drop me an e-mail; I have an extreme excess of both.
I would also like to see an op-amp based equivalent circuit of these just out of curiosity though.
Old 19th June 2009, 07:26 PM   #10
Well, I might let my natural laziness take advantage of such a kind an offer.
But on the other hand, I hate to use good, sophisticated parts for menial tasks.
And anyway, the problem would still be nagging me afterwards... it's like having a word on the tip of the tongue. I cannot sleep properly until I've found it.
But anyway, thanks for your generous offer. When I'll really need such an amplifier, I'll come back to you.
See? You too have been contaminated
Diff drive bigwill Tubes / Valves 38 6th February 2009 05:33 PM
diff between dipole and IB bser Multi-Way 6 18th November 2004 09:23 PM
diff or parallel dac TJ Digital Source 6 10th November 2003 12:14 PM
help with diff. output Raj1 Digital Source 4 9th September 2003 05:03 PM
Page generated in 0.33689 seconds (26.39% PHP - 73.61% MySQL) with 11 queries
