High current mirror ?
Old 17th June 2009, 10:09 AM   #1
forr is offline forr  France
forr's Avatar
Default High current mirror ?
Can current mirrors using 2, 3 or 4 transistors be made to reliably hold currents up to 100 mA ?
Old 17th June 2009, 02:15 PM   #2
jcx is offline jcx  United States
degeneration provides feedback that increases ratio control in the face of device variations - the higher the Vdrop across the emitter Rs the more feedback correction you get
you can also inrease device gain with Sziklai/CFP - the cost is the voltage burden of ~1V
Old 17th June 2009, 02:21 PM   #3
Elvee is offline Elvee  Belgium
Elvee's Avatar
The two-transistor version risks some problems of thermal tracking, but the 3 and 4 transistors should be OK, with devices of suitable size.
Old 17th June 2009, 08:01 PM   #4
forr's Avatar
Thanks for your replies.
A Sziklai pair has some appeal.
Do you think of of the input of the CM with a single transistor connected as a diode, as usual, mirrored by the controling transistor of the Sziklai pair, which then can provide current gain as you said ?
I feel silly to have never thought of such a scheme but I am not aware of anybody having ever used it. I do not see any reason why it should not work (I can't imagine how a Sziklai can be used as the input of a CM).
My initial question comes from the fact I have not seen CM's used with more than 10 mA per branch.
Old 17th June 2009, 08:04 PM   #5
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Default Re: High current mirror ?
Yes. I use 11 of Toshiba2SC1815 transistors between 2 copper plates for such a purpose.
The Devil is not so terrible as his math model is!
Old 17th June 2009, 08:16 PM   #6
syn08 is offline syn08  Canada
Default Re: Re: High current mirror ?
YMMV, but the output impedance will be anywhere but good. Ro=VA/Ic where VA is the Early voltage. Ro is the same, disregarding the number of 2SC1815 you are paralleling.
Old 17th June 2009, 08:19 PM   #7
Wavebourn's Avatar
Default Re: Re: Re: High current mirror ?
I'm concerned about accuracy, especially with thermal effects in mind. I can't reveal all details here, JC is reading.
Old 17th June 2009, 08:40 PM   #8
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
How about a servo loop with two sense resistors, an op-amp and a buffer transistor? (probably MOSFET to avoid base current).
Times have changed...
I use to feel like the small child in The Emperor's New Clothes tale
Old 17th June 2009, 08:47 PM   #9
forr's Avatar
Hi Eva,
I have thought of that before posting the question, buf it probably won't be as fast as a simple scheme and may introduce stability problems for what I have in mind.
Old 17th June 2009, 08:49 PM   #10
Default Re: Re: Re: Re: High current mirror ?
Do you really think JC and perhaps other guys in the industry are ripping off design ideas from this forum? I don't think so, but if God forbid this proves to be right, and if it would be worth of ( unlikely ) I may decide to legally pull some eyes. Been there, done that. BTW, under the US law patenting is not really required to protect an idea. You can make a case in court if you keep track of your stuff.
High current mirror ?Hide this!Advertise here!
Current Mirror Discussion AKSA Solid State 348 24th March 2017 09:21 AM
Current Mirror: The V-mirror rtarbell Solid State 1 19th November 2008 02:27 PM
no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS? maxpou Solid State 31 17th June 2008 04:31 PM
A special current mirror pjacobi Solid State 13 16th June 2008 04:16 PM
Current mirror abzug Solid State 7 1st January 2008 07:03 PM
Copyright ©1999-2017 diyAudio
