Help: plate amp blown - need help to fix
Old 14th June 2009, 11:25 PM   #1
konman is offline konman  Australia
Default Help: plate amp blown - need help to fix
Hi
I have a blown amp module from a Digitech cs2457 jaycar spec sub
Symptoms: Fuses blow as power is applied after the toroid
Speaker is blown into a crunchy voicecoil mess
caps are blown - atleast one of them.
relay has scorch marks inside.
Is it worth trying to fix this or could there be something else blown apart from the capacitors.
If i try and replace capaciters would i have a fighting chance? Would the fuse blow because of this?
I have a replacement 4 ohm driver to go in (sony car sub) will do the job for now.
would the torroid be ok? or could that have bit the dust also.
thanks for your thoughts guys
amp module
amp module bottom
left cap blown
relay blown
plate amp back
plate amp front
torroid
Old 14th June 2009, 11:32 PM   #2
mbates14 is offline mbates14
depends on where the fuse is. if its after the torroid, it is probably ok. if its before the torriod, it needs checked.
Old 14th June 2009, 11:34 PM   #3
jaycee is offline jaycee  United Kingdom
You could test the toroid easy enough by hooking it up with the secondaries disconnected and seeing if the specified 40V AC is still coming out. I'd recommend doing this through an incandescent bulb in series with the Live wire to limit any fault current. Before you do this, you should test to see if there is any conductivity between primary and secondary windings. If there is, bin it as it's dangerous.
Those caps are well shot, and to produce that kind of damage you can guarantee the output transistors and drivers will also be shot. The bridge rectifier may also have blown (it seems under rated) and that's what took the caps out. As for the rest, you'd have to pull the parts and test.
One pair of outputs (I guess they're MOSFETs) seems silly at that kind of voltage, for sub amp duty. The relay obviously wasn't rated to break the current either.
Old 15th June 2009, 01:26 AM   #4
Thanks for your replies,
yes both fuses blow after the toroid. The one before located at the plug is ok.
I guess this is for the spare parts bin then.
Could I replace this with an amp module from 41hz.com?
What wuold be a good replacement?
Cheers
Help: plate amp blown - need help to fixHide this!Advertise here!
Help: blown plate amp module konman Class D 3 24th October 2012 11:08 AM
Plate Current VS Plate Voltage Graphs Captn Dave Tubes / Valves 2 13th February 2009 08:57 PM
ECC83 - Long Plate vs Short Plate poynton Tubes / Valves 16 17th February 2008 07:42 AM
Subwoofer Plate Amplifier Base Plate supplier? jwells777 Parts 1 11th May 2003 07:40 AM
Copyright ©1999-2017 diyAudio
