i need an opinion here.... i was playing with a output buffer concept for a hybrid power amplifier... i would like You guys to tell me if this will be o.k.... an opinion is needed.... this in attach is only the output buffer of the amplifier - the input will be some tube stage with the gain of arround 10-12.... maybe an Aikido stage or just plain common cathode using one triode only - this has to be decided... i am thinking of using 5687 with a decent plate current and a ccs in the plate of the tube.... somehting like that... or Aikido stage with 6n6p tube or 5687 at the output.... this is still to be decided.... what i need you to tell me if this is o.k.... would it be good enough to try to build and to PROBABLY get a good result..... thanks in advance.... best regards daniel |
#2 |
Hi Sparkle;
here is a good thread to start learning from: http://www.diyaudio.com/forums/showt...08#post1842408 Don't learn from D. Self when building class A hybrid amps; he did not write his book about them. He wrote a book about some typical topology only.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#3 |
Wavebourn - thanks for the link - very nice informations there....
=========== but... i wanted to hear an opinion about the design from the first post of this thread... and this is not Class A tube/mosfet design but push-pull class AB using transistors at output.... so, please - comments on that design and eventually informations on how to improve it - i am preety sure it will work - i want to improve it if possible - not to convert it to mosfet ...... thanks in advance and best regards |
#4 |
Hi Sparkle,
One question is, whether you will have even a little global-negative feedback to provide better damping factor as none is indicated in your first post ? Edit: might you want to add a charge-suck out capacitor across the bases of the output devices. Helps with the cross over switch off of the devices ? A value of 100nF or so is common.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#5 |
good point Bigun - i forgot about the suckout capacitor... thnx...
global feedback... well - i'd like to go without it - but don't want to discard the idea of having it (maybe a little bit) too.... so, that is also an open question..... |
#6 |
My experience is, that the high input impedance is the most important. So I would use triple darlington output, and use the 100uF caps as bootstrapping the resistor string. You can get 100-200kohms input impedance with this modification, and single stage E88CC can drive the amplifier.
Sajti |
#7 |
R.I.P.
This looks quite interesting, at least on paper.
BUT you must be able to make the bias setting adjustable, there is no hint of how much standing current you will get if you just build it up as drawn. I suggest the 22k in the BD139 circuit becomes a trimmer, a precision 10 turn trimmer if at all possible. And start it up with the trimmer set to zero ohms and open it slowly while monitoring the standing current. Then it may be quite good. But as someone else said, it will need a lot of drive current from the tube stage, but you don't go into that. Regards, Allen (Vacuum State) |
#8 |
#9 |
R.I.P.
Sajti,
That looks really good and far easier on the tube stage! I'm tempted to try it. And a correction to my previous suggestion regarding making the 22k a trimmer - that's unsafe, as if the trimmer goes open circuit the output stage will suddenly have huge current, far better to make the 8k2 the trimmer. Then if it goes O/C the current just shuts down, not blows up. Regards, Allen (Vacuum State) |
#10 | |||
i forgot to draw the trimpot in Vbe multiplier - thanks for input - i willdo that later today... i wanted to use a trimpot on that position instead of 22k like you said.... yes, it will need a lot of current - i will deal with that - 5687 or 6n6p, 12B4 or something will do the job... the concept of the input tube stage is still open... i would like to deal with this output stage first, to build it and than to experiment with different input tube designs to see which one will do the job the best possible for the given output buffer.... that is my intention.... Quote:
1. question - what are you using for the input to drive this output stage 2. question - how does it sound overall (on which equipment)....?? thanks..... i like the idea of using those ccs's in emiter of the driver trasistors.... they really sound good ... i just have to make the rest of the circuit up to what they can do..... best regards to all... this thread is progressing nice - really thanks to all of You... |
| Hybrid Output Inductor | Electrone | Class D | 12 | 30th April 2009 04:27 PM |
| opamp. buffer, or hybrid for mu=1 ? | baald | Solid State | 1 | 29th April 2006 05:34 PM |
| New Hybrid Output Stage and booster for SE Amp | smoking-amp | Tubes / Valves | 3 | 20th March 2006 02:24 AM |
| Page generated in 0.19575 seconds (65.30% PHP - 34.70% MySQL) with 11 queries |
