I'm wondering if anyone can recommend a decent inexpensive monolithic transistor IC (i.e. multiple matched transistors on the same die) for input stage design? I'd like to use such an IC for experimenting with differential gain stages, temperature compensation, and matched transistors for current sources, that sort of thing. Any advice would be appreciated!
#2 |
I could not fine any, that's why recently bought 5,000 of 2SC1815
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#3 |
What about the old famous LM394?
#4 |
There was a recent thread about matching transistors that had some recommendations for monolithic dual/quad transistors for input stages. Additionally, if you want some specifically for current mirrors, then I like BCV61/BCV62 because they are internally connected as current mirrors already, so they only have four pins.
http://mrevil.pwp.blueyonder.co.uk/ |
#5 |
MAT02/03/04?
#6 |
i've used mpqxxxx series parts from sprague (also from motorola) years ago. neither still supplies these.
however, it appears central semiconductor still has them: http://www.centralsemi.com/PDFs/products/LSSGP079.PDF mlloyd1 |
#7 |
I'm pretty sure these parts are not matched.
#8 | |
#9 |
Hum, that is pretty impressive. All of the individual devices must have come from the same die. I don't suppose this is guaranteed, but it makes sense that this would normally be the case. A cheap way to get matched devices for no premium.
| Differential transistor input stage | aguantesoda | Solid State | 48 | 11th April 2007 07:36 PM |
| unusual design of input stage | Kuzmenko | Solid State | 18 | 15th January 2007 10:22 PM |
| help me design an input stage for 6b4G PP | AudioGeek | Tubes / Valves | 11 | 2nd September 2005 08:48 AM |
| LM6171 input stage design | capslock | Solid State | 17 | 20th March 2002 04:49 PM |
| Page generated in 0.10805 seconds (75.93% PHP - 24.07% MySQL) with 10 queries |
