#21 | |
That's, why he became so silent.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#22 | |
100's on C8 (red). I guess C7 can go , I'll try it. It does not seem to add another pole to the amp. If you replace the cascode with a resistor (22k) , it does. I will have check whether removing C7 has any effect on THD, FFT , and loopgain response. OS |
#23 |
Hi Ostripper,
In fact, Q6 replaces a resistor in parallel with a capacitor of an initial design that was first published by Hitachi, I think. So at high frequencies, with this older scheme, C7 will continue to see almost no voltage variations, because alternatively coupled to the collector-base node of Q7. The purpopse of common base Q6 or the old RC network is to maintain DC voltages at collectors of Q4 and Q5 roughly equal, getting the same thermal dissipation for them. |
#24 |
OS,
The pcb explanation makes good sense now, I hadn't understood how you were doing it properly before. The other question I had was bass 'slam' - is this just down to having a big caps on the input and feedback loop or is there more to it than that ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#25 | |
as the ability of the OPS to handle transients is the key. Then , your assumption is also right , having more current and voltage does have a MAJOR impact. The 2 OP supersym's I gave to DWB did not have the "slam" that the new 4 pair boards do on the same PS. Conversely,when the 2 op pair boards were run on an 300VA EI, the bass was normal(not impressive). With the 1500VA and 100's of K uF , ULTIMATE scary bass. So , with each improvement (2 to 4 pair , 300Va to 1500VA) a very noticeable bass improvement occurred. With the 2 pair OPS , I think beta "droop" at high level , hard loads affected bass response. OS |
#26 |
Hi Gareth,
You are really talking about the ability of a circuit to deliver high currents accurately. The ability of an amplifier to control a bass driver. I think most well designed amplifiers can do this easily. Most of these will be solid state and be of a higher power. That way you don't run into protection circuits limiting the current, or a loss of gain in the output stage that allows the current output to drop. Being a subjective thing using a wide variety of speakers and cables, this is really not a valuable term. There is no real definition and really only points to amplifiers that have limited power or current output. In short, nothing to worry about. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#27 | |
..Todd |
#28 | |
That is what I think we all want , the most universal layout.The only reason mine is 5.5" X 8" is I made it for the stealth amp. OS |
#29 |
Hey Chris, this would make a nice 4B retrofit project wouldn't it?
..Todd |
#30 | |
Yup. Perfect. In fact, it ain't too different from my DX HRII-55 layout. (Based loosely on Quasi's layouts.) ..Todd |
| Supersym patent | Rescue Toaster | Pass Labs | 6 | 22nd January 2008 09:49 PM |
| philips cd 202 first generation | daveyboy1964 | Swap Meet | 1 | 30th December 2007 08:40 PM |
| pwm generation | sundeep2802 | Class D | 1 | 18th March 2005 05:39 PM |
| Page generated in 0.11603 seconds (81.20% PHP - 18.80% MySQL) with 11 queries |
