#11 | |
The triple would only be needed with lower beta MJ's (TO-3) or more than 5 pairs. At 4 pair and 2R the VAS only sees .4ma load (this is where the .002-3% extra THD comes from). that is very acceptable for a type 2 EF passing 15A (way above the SOA of these devices). The triple , while I have worked the stability issue out , adds parts and complexity with such a small return.( .006 vs .01 @ 2R /15A/ 20k) Try it on the spice file , add some mje340/50's or mpsa42/92's predrivers. 1K emitter resistance, 3.3k for the upper Vbe resistor. It works nearly the same. OS |
#12 | |
We're talking the same words but about different things, I think... I was asking if you wanted to purposely route the power rails adjacent and parallel to each other, a bit like how some folks twist together their power feed wires. It puts the power rails on one side and allows you to put the sensitive signal wiring over on the other side of the pcb. That way large currents stay away from small currents with no big current loops (magnetic parasitics). Well, just a thought I do want to understand more about the Bass. People have commented that supersym has outstanding 'slam' compared with some other amps. Why ? It has to be more than having a 2.2uF input cap.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#13 | |
in a real circuit they can get hot enough |
#14 | |
I usually put (c) as output , (a) as the base of the feedback LTP transistor. Probe goes between (c) and the NFB resistor (27kj in this case. Attached is plot of V(c) and -V(c) / (a). OS |
#15 | |
Not understand what you are measuring? (open loop?) |
#16 | |
I questioned the need for a triple on a low power amp like my Adastra, but when I tried it (using KSC1845/KSA992 for predrivers there) the drop in THD was significant enough to warrant me keeping them. I suppose the difference there is that that isn't a differential VAS. |
#17 | |
Hi ostripper,
Try to keep the voltage across the input diff pair lower than 8 or 9 VDC if you can. A 6 V drop might be a good target. Allow the cascode transistors to soak up the excess. Quote:
I really, really dislike mosfet output stages. Jan made the only one I have liked the sound of so far, and that was an error correction amp. One suggestion for you. Why not design it as a voltage amp PCB and an output PCB? That way you can keep the temperature changes around the voltage amp section minimal, and allow for nice, thick traces for your output transistors. A side benefit is that this would allow you to try out different output sections easily, same for voltage amps. Just a thought. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#18 | |
First is a Yamaha 300w (pro amp). ![]() Here it looks typical with fat rail traces running parallel to the main emitter resistor rail (output)and the basestopper traces above that. any small signal stuff is away from this heavy current. My scheme is similar to the yamaha rail wise. I noticed on all the OEM's the grounds go everywhere and only become "sane" at the main caps (a real star) , the OEM's even use off value caps to decouple (counteract) parasitics from long ground traces... We can do better. On the rest of the board I "wrap" the Main caps ground return around the outside of the board with the lower level rail (VAS and LTP) ground returns inside of that. So anywhere at the back of the board is "surrounded" by the low current returns.Inside of those 2 groups of ground traces ,I then try to completely surround the LTP and input components with the "lifted" ground (R27 - 22r). All 4 of the capacitor ground returns are equal in length. See the image. ![]() Also since the amp is referenced off of that main "star" in the middle , the speaker return should go there to (ZERO hum). JVC and others do the "Copper bar thing" emulating a double sided layout by soldering copper bars on the component side of the PCB. It works ,I did this on the "little' supersym. (Gave them PCB's to Danielwritesback). The zobel ground and the NFB return also have an ideal setup. The zoble return should not snake through the input section or even the VAS , a straight wire back to the star is good. The nfb should be attenuated by its resistor AT the takeoff point , then run through a shielded wire grounded to the signal ground at the LTP. OS |
#19 | |
Ahh , howdy.. Chris..
I see why you said 9V , Jfets are becoming obsolete at 30v and above , so if i do it this could be the way .. http://www.onsemi.com/pub_link/Colla...UD3170NZ-D.PDF nice matched pair mosfet , back to back zeners , 20v VDss.. But you hate mosfets As far as OUTPUTS , quasi (power amp under development) has shown the IRF240 /9240 are very interchangeable with BJT's . His "brother of quasi" is a clone of his NMOS 350 , except for a different Vbe and gate protection. I can most likely predict that a supersym with IRF's would sound nearly the same as with the BJT's but have double the SOA and be a 350 watt /8R- 500w /4R amp. (Don't worry , NJW'S and the 2sc5200's are the main project.. you can't take away my BJT's) What IS a problem is jfet and Mosfet LT models.. nowhere as good as the BJT's. OS |
#20 |
Hi Ostripper
---The only benefit of the 2 Cdoms is that they load the LTP equally at low levels.--- My concern is that current flows through C8 because of the varying voltage at Q5 collector, but Q6 collector voltage being almost fixed at about +0.6 V above ground, current variations in C7 can only be very small. So I don't think we can consider that C7 and C8 load the LTP collectors equally. |
| Supersym patent | Rescue Toaster | Pass Labs | 6 | 22nd January 2008 09:49 PM |
| philips cd 202 first generation | daveyboy1964 | Swap Meet | 1 | 30th December 2007 08:40 PM |
| pwm generation | sundeep2802 | Class D | 1 | 18th March 2005 05:39 PM |
| Page generated in 0.16247 seconds (75.13% PHP - 24.87% MySQL) with 11 queries |
