#101 |
OS,
With 77V rails you don't easely approch clipping, ofcourse i understand that. But I guess you are gonna make this amp also available to the community and I don't think everybody is going to use railvoltages like you do. I think there should be an option..... Thanks ! |
#102 |
Thanks for keeping it "straight" , Andrew. Forgot about the cascode.
(reality below) OS |
#103 | |
OS |
#104 |
Ostripper, what is the function of these diodes and resistor 22 Ohms?
Fig: |
#105 |
To add some isolation between signal ground and power ground
#106 |
Should Q6b,R17,R18 junction really go to signal ground? It doesn't in the original Symasym.
Brian. |
#107 |
I certainly would not take that cascode voltage reference to Power Ground.
regards Andrew T. |
#108 | |
The Ground can be exposed either at the amplifier or at the far end of the interconnect. This exposed part must be connected to the Safety Earth. The diodes should provide the high current route from Signal Ground to Safety Earth. Signal diodes are the wrong choice for this duty. 1n4001 would be better. 1n5401 better still. Do we need the 22r? What effect does it have on the amplifier's performance?
regards Andrew T. |
#109 |
Hi ,
I'am ready, to hear some comments, regarding my PCB for supersym , and I will fix any error http://i39.tinypic.com/jgirk9.jpg Regards Alex mm. |
#110 | ||
http://www.diyaudio.com/forums/showt...086#post739086 But, I do not agree with the use... |
| Supersym patent | Rescue Toaster | Pass Labs | 6 | 22nd January 2008 09:49 PM |
| philips cd 202 first generation | daveyboy1964 | Swap Meet | 1 | 30th December 2007 08:40 PM |
| pwm generation | sundeep2802 | Class D | 1 | 18th March 2005 05:39 PM |
| Page generated in 0.28337 seconds (35.22% PHP - 64.78% MySQL) with 11 queries |
