Old 11th June 2009, 03:10 AM   #1
Default Amplifier
I have this amp and I am wondering if by looking at the design, you could tell if it is a good design and would be a good candidate for use. It was working but the preamp is now lost. My next question is: How can I determine the connections (ins and outs)? I am a newbie. Well not too new but I have not been actively studying and doing my homework.
Old 11th June 2009, 03:54 AM   #2
tinitus is online now tinitus  Europe
Obviously you will need serious help with this
Old 11th June 2009, 05:32 AM   #3
h_a is offline h_a  Europe
h_a's Avatar
What a mess - is that a commercial amp or home-brew?
Seeing that mess I imagine your electronics knowledge will be in good shape when you have succeeded in fixing that one.
Have fun, Hannes
Old 11th June 2009, 06:33 AM   #4
What are the culendrical objects? tubes?
Old 11th June 2009, 07:19 AM   #5
Looks like a tube amp from the bottom and as if the designer had a capacitor fetish. Is it a stereo tube-driven SE class-A transistor amplifier? Or are the transistors only used as voltage regulators?
The first step should be to draw a schematic, if you don't have one. Going by the photo only tells us that it is old and that the builder prefered point-to-point over PCB. That could of course be a sign of the times, when it was built. There might still be a good design behind it, even if it is not good-looking.
If you post photos, they should be at least big and sharp enough to recognize all components. Looks, like some quality components were used, while the transformer says low power.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Page generated in 0.10473 seconds (65.10% PHP - 34.90% MySQL) with 11 queries
