Old 10th June 2009, 03:42 AM   #1
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
Default Paper clips as TO-220 heat sinks
These are definitely my people
http://tangentsoft.net/elec/diy-hs.html
Bottom line: the paper clip beats the coins.
Old 10th June 2009, 07:11 AM   #2
Nrik is offline Nrik  Denmark
Amazing
STOP - Hammertime!
Old 10th June 2009, 06:24 PM   #3
cbdb is offline cbdb  Canada
Ever try pieces of aluminum beer cans? You can cut (with siccors) and bend them to custom sizes and shapes.
Old 10th June 2009, 06:35 PM   #4
jwb's Avatar
Usually I use cut-off bits of right-angle aluminum extrusions like these
Old 10th June 2009, 06:51 PM   #5
HighTec is offline HighTec  Croatia
HighTec's Avatar
Hmm..
are you sure that those are aluminium extrusions? They look a bit ...rusty. Steel perhaps?
Old 10th June 2009, 07:02 PM   #6
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Gee, i never knew aluminum angles were hot rolled.
Nice round edges, they even have a corroded hot roll skin.
The academic dime article is fun though.
Looks like Sponge Bob has killed another thread.
Old 10th June 2009, 08:11 PM   #7
jwb's Avatar
No those are obviously steel, but when you search Google for "angle iron" that's what you're likely to get.
Old 10th June 2009, 11:30 PM   #8
wwenze is offline wwenze  Singapore
The paper clip idea is effective though, because it is "self adhering".
Read this before but forgot totally about it. It just solved my resister cooling problem. Thanks.
Old 11th June 2009, 02:50 AM   #9
taj is offline taj
taj's Avatar
Yes, the beauty of the paperclip idea is that you can use a choice of clip sizes and bend the "fins" in whatever direction is convenient. I love it. Just make sure you have great thermal contact with the device.
I've used "fast-on" connectors wrapped around TO-92 transistors as heatsinks (to reduce thermal variation). Add a [solid] copper wire link between 2 of them for differential pairs, to keep them them [somewhat] thermally 'synchronized'.
I wonder what other household commodities we can use for DIY Audio applications that perform nicely as compared to commercial products.
..Todd
Old 11th June 2009, 04:03 AM   #10
tinitus is online now tinitus  Europe
Default Re: Paper clips as TO-220 heat sinks
How do you tell
Its hard to imagine with that little contact surface of the paper clips
The copper coins seems nice, but have to be grinded smooth to work
With the coins tho Im thinking that the insufficient cooling surface might just make heating issues worse, as its just holding back the heat, and dont remove it
Might be why paper clips seem to work better, as they still allow the heat to get away
It says, "naked transistor not yet tested", which to me makes conclusion pointless
Very easy to do a nice effective finger heatsink with any kind of metal sheet, be it alu, copper or what ever
As long as its stable enough to make proper contact
A proper heatsink still seems far more effective, so I really dont see the point, other than its fun
Seems to me he made the same conclusion, or maybe I dont understand it right ?
What might this mean for heat-sinks? seventenths Everything Else 17 1st July 2008 07:20 PM
Big heat sinks AR2 Swap Meet 0 30th December 2006 07:51 AM
Heat Sinks serengetiplains Parts 3 3rd January 2006 06:41 AM
where do you get your heat sinks ? percy Chip Amps 12 16th August 2005 07:00 PM
Big Heat Sinks dshortt9 Parts 15 4th November 2002 07:36 PM
Page generated in 0.24050 seconds (33.66% PHP - 66.34% MySQL) with 11 queries
