Paper clips as TO-220 heat sinks
Old 11th June 2009, 04:22 AM   #11
okapi is offline okapi  United States
okapi's Avatar
can you use a paper clip to hold a coin on?
Old 11th June 2009, 04:49 AM   #12
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
No point if a coin doesnt work
But you have a good point tho, if the clip is reliable in the long run
I like the idea of using beercan alu
Clamped with a small piece of stable metal
sometimes we know very little, and sometimes we know too much
Old 11th June 2009, 05:31 AM   #13
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
I once needed to improve a heatsink, so cut 1/4" aluminum wire on 3" peaces, stuck them between fins of the heatsink, and glued by epoxy. It looked like a hedgehog, but the temperature dropped down significantly.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 11th June 2009, 06:33 AM   #14
galaxy786 is offline galaxy786  Pakistan
Perhaps coins could give better results if hammered to more smoother and thiner surface. Thats easy. I have done it many times but never considered that it could make a heatsink. Not dure if it is cheaper w.r.t the quality.
Old 11th June 2009, 06:55 AM   #15
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
I've used coins as heatsinks for some small bridge rectifier modules (those little tiny round ones). I just stuck them on with epoxy (JB weld,lol) and they worked great. I even built up a larger finned 'heatsink' with a stack of off-set pennies all epoxied together,much like in the picture. It actually worked quite well!
(Edit: I think the trick to using epoxy,is to use some that is meant for (and contains) metal.It probably has lower thermal resistance?! Just a thought.)
Old 11th June 2009, 01:31 PM   #16
CBS240 is offline CBS240  United States
CBS240's Avatar
Originally posted by cbdb
Ever try pieces of aluminum beer cans? You can cut (with siccors) and bend them to custom sizes and shapes.
To cool a TO-18 transistor. It worked, the trany didn't blow out as it did without the beer-sink.
As for pennies, you need to get some old ones, pre-1980. They are solid copper. The new ones are only plated.
Old 11th June 2009, 05:45 PM   #17
GPG is offline GPG  United States
The fastest TO-220 heat sink is a small binder clip. It is much better than a lowly paper clip!
You can also arrange the little levers for the best appearance.
For production, you can even remove the levers to prevent tampering.
Paper clips as TO-220 heat sinksHide this!Advertise here!
What might this mean for heat-sinks? seventenths Everything Else 17 1st July 2008 07:20 PM
Big heat sinks AR2 Swap Meet 0 30th December 2006 07:51 AM
Heat Sinks serengetiplains Parts 3 3rd January 2006 06:41 AM
where do you get your heat sinks ? percy Chip Amps 12 16th August 2005 07:00 PM
Big Heat Sinks dshortt9 Parts 15 4th November 2002 07:36 PM
