Bypassing electrolytics - GOOD or EVIL ?
Old 11th June 2009, 10:44 PM   #21
jrockhead is offline jrockhead  United States
Sorry, I cannot. However, in audio use, the often massive encapsulation is unfortunate.
As I expected..........
Old 12th June 2009, 02:32 AM   #22
Ziggy is offline Ziggy  Australia
Account Disabled
Thanks all.
Andrew, I think you nailed it.
The good thing is that at the 8 ohm setting,even though my speakers are around 5 ohm impedance, the power transistors/heatsinks are not hot - just slightly warm(even when playing music loud for lenghthy periods.So, I guess it's safe to leave the switch in the 8 ohm position.
Recall somewhere that mention was made to NEVER use such a switch as it was detrimental to the sound and involved additional circuitry?
Old 12th June 2009, 02:57 AM   #23
Account Disabled
After many hours of constant run in by leaving the amp on,24/7, the original beeswax block and large motor run cap set up has gotten better sounding. The sound seems very fast, dynamic and great controlled and deep low notes. Snare drums or drums of any sort have an amazing speed and timbre that is a pure delight. You can easily hear drum skins being hit with sticks or felt beaters - no problem distinguishing which is which or what type of drum is in action.
All in all, the cap bank/mod has truly proved it's worth in combination with the IXYS rectifier block: VB068 - 12N07 1-PHASE RECTIFIER BRIDGE (ECO-PAC1 case).
Old 12th June 2009, 04:45 AM   #24
Account Disabled
Correction : IXYS number is : VBE 55-06 N07
Old 12th June 2009, 09:20 AM   #25
On Hiatus
SY's Avatar
Bigoted and personal attacks removed.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 12th June 2009, 12:02 PM   #26
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Shame, just as i was nailing down the receiver's KR-V number.
The knob tip looks very interesting though, due time to try an alternate experiment technique, i already wonder what i'll sound like.
Herbs shouldn't be advocated, they'll pollute the object-ive experience.
Maybe some Amyl Nitrite for an enhanced recording during clipping sequences.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 12th June 2009, 12:15 PM   #27
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Originally posted by G.Kleinschmidt
P.R.A.T can be experienced much more intimately
And G.Kleinschmidt will graciously allow use of his collection of avatars for a full audio-visual experience.
Old 12th June 2009, 12:32 PM   #28
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Bypassing big Elko with small plastic cap is not as simple as it looks. The Elko and the small bypass cap can form LC oscillator, frequency peaks and dips can be perceived as "better details" or "better treble".
There's a lengthy discussion about this matter on this website, under power supply section or classD section or "Snubber" topic.
Some explenation made by member EVA.
Old 13th June 2009, 07:30 AM   #29
GK is offline GK  Australia
Please don't post a picture.
Old 13th June 2009, 07:41 AM   #30
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally posted by jrockhead
All in all - a different sound was the end result.......BUT.........SOMETHING IS NOT RIGHT
Uh Oh......
.........on large dynamics such as percussion music, closely miked kettle drums, I noticed some distortion coming in to the equation. Replacing the bypassed bank with a couple of 20, 000 uf Nippon Chemicon vintage caps, the distortion went away so it seemed.
I always thought that the metal wrapper on an electrolytic is actually part of the unit and needs to be there for proper operation. Not to be confused with "nude" capacitors with the paper or plastic insulating wrapper removed. I still don't understand "nude" capacitors, what difference could it possibly make but I digress.
So putting back some "normal" caps made the nasties go away, I'm thinking you ruined a perfectly good set of caps. Try the same caps in there without removing anything and use the same bypass caps and listen to how it sounds. My curiosity is now fired up.
You probably forgot about wires that go from rectifier to caps, then from caps to your amp. You can shunt your electrolytics by some films right there, with as short as possible wires. Or, you can add fat electrolytics on long wires. But not vice verse.
The Devil is not so terrible as his math model is!
Bypassing electrolytics - GOOD or EVIL ?Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
