I am having a problem with a Hafler Five Hundered. I am intermitantly losing channnels in and out. When the channel fades, sometimes the left, sometimes the right, I can turn the power switch off and back on quickly and both channels will work fine again for a bit and then one will fade and I can do the same thing over again. Everytime I flip the power switch off and back on, both channels work properly again. If I leave it on one side will be fine and one will fade in and out. What is going on? when both channels are going it sounds good. What should I look at" Any help greatly appreciated. Thanks, Kyle
#2 |
Get the manual on the net. Most probably a defective aging TR401 inrsuh limiter. Seems to often happen. |
#3 |
Cool thanks. One thing I did notice is that after letting it sit all night long powered on, it doesn't seem to be having channels drop out. It looks to be a component which functions when warm but not correctly when the unit sits off for awhile. Would this limiter be consistent with that?
#4 |
yes.
you can consider replacing it entirely with a soft start circuit that controls a relay with a power resistor for the current limiting on start up. there are circuits you can find if you search here... Or alternately, bypasses the present part entirely after a start up period of a few seconds... same idea. _-_-bear
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#5 |
It can't be the inrush limiter.
I would check the speaker relay. Pop the cover and run a pair of jumpers across the relay contacts.
Candidates for the Darwin Award should not read this author. |
| Hafler TA1100 problem | vfluxrob | Chip Amps | 7 | 31st December 2009 03:17 AM |
| Hafler DH220 problem | Reveler | Solid State | 10 | 6th May 2009 03:07 AM |
| hafler xl-280 problem | zerohead_ak47 | Solid State | 2 | 28th December 2008 06:41 AM |
| Hafler DH 200 problem | guy_b_g | Solid State | 1 | 22nd November 2004 12:09 AM |
| Hafler DH 500 problem | confused dh500 | Solid State | 7 | 28th February 2004 08:51 PM |
| Page generated in 0.10971 seconds (69.49% PHP - 30.51% MySQL) with 10 queries |
