I currently have IN4007 rectifying diodes in my amp but have been told the UF4007 or SF4007 are by far better rectifiers. I've looked over the data sheets but has anybody truly played with these or found if there is indeed a significant change in any audio qualities?
#2 |
How can anyone answer this question? It depends on your experience, ears, system, taste. Maybe you will like them better, maybe not. Statistically, the average diyer seems to completely deaf so it shouldn't really matter. Of course it will only cost cents to find out for yourself...
#3 |
where are you going to use this UF4007 or SF4007 ? DAC or amp ?
#4 |
Whether or not there wil be a sonic advantage depends much on the circuit, the layout, the grounding, the bandwidth... Since they're cheap and can't hurt, I use them as a matter of course.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#5 |
probably the supply rectifiers,- i wouldnt bother there is no advantage
| Rectifying Heater Supply | AmpBuilder225 | Tubes / Valves | 2 | 7th April 2009 07:35 PM |
| Rectifying multiple secondaries.. | DigitalJunkie | Power Supplies | 6 | 15th February 2009 03:26 AM |
| PSU Rectifying Diodes - Help needed | aircondition | Digital Source | 3 | 17th December 2007 11:07 AM |
| Using discrete diodes instead of rectifying bridges. | Peter Daniel | Solid State | 23 | 4th September 2002 06:27 PM |
| rectifying....what would be prefered (aleph PS) | hifi | Pass Labs | 12 | 20th October 2001 10:34 PM |
| Page generated in 0.10344 seconds (63.95% PHP - 36.05% MySQL) with 10 queries |
