#11 | |||
(' ')Quote:
#12 | |
As you say yourself, THD does not tell the whole story so what would a bunch of figures improve for the customer? And if it did, you need to know the whole picture, like that 1% THD at full power is still less than what a typical speaker produces at this power.* As for the manufacturer marketing is certainly cheaper than R&D, especially in a field where real inventions are rare (audio technology has about 100 years of history!). That's not to say that I wouldn't like to see more plots in their documentation Have fun, Hannes * ever seen THD-plots for speakers? I know of a single manufacturer that specifies THD for this stuff (JBL pro equipment).
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2 transistor kits |
#13 | |
As you all know, gold is a good plating material for electronics because it does not tarnish and therefore consistently makes a good connection -- electrical connection, that is. Toslink cables are digital optical cables and make no electrical connection at all. Thus, gold doesn't help at all. One can't even argue that the gold looks good, because it's plugged into the back out of sight. But there this company was selling them. |
#14 |
It's crucial that amplifiers have one of these in order to obtain acceptable sound. Nothing else matters much.
Pure Obtainium
#15 | |
#16 | |
http://www.dagogo.com/StageIIIZyklop.html ![]() Wow , handmade in the USA by greedy capitalists. Seriously , the benefits to detail and soundstage that are reported would be better realized with a 1KVA industrial toroid and 100k uF of capacitance ( only $300). OS |
#17 |
Banned
You have been reading the wrong books.
Try 'Zen and the Art of Motorcycle Maintenance' by Robert M. Pirsig, or 'The Teachings of Don Juan - A Yaqui Way of Knowledge' by Carlos Castaneda or even 'The Integration of the Personality' by C.G.Jung. You are suffering from a fragmented world view. Aspects of your post are mutually incompatible. w Do not adjust your set. Normal service will resume as soon as possible. |
#18 | |
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#19 | |
Nope, I was referring to the $6400 power bar in my link. Will make any amp sound good. ..Todd |
#20 |
It is difficult to separate the insults from the recommendations.
Most importantly, audio design is a bit, both objective and subjective. That is what makes it interesting. For example, you can make some amp or preamp that MEASURES very, very well, yet doesn't sound as good as you would presume that it should. Why? How can this be so? Yet, another amp or preamp, might sound better, yet its specs, while somewhat different, should be inaudible by every objective standard of what the ear can hear. IF and when you have been subjected to such an experience, especially if your own design failed to satisfy critical ears, that you've grown to trust, then you go back to the 'drawing board' and hopefully use approaches that don't necessarily follow standard engineering, but are more akin to 'Zen and the Art of Motorcycle Maintenance'. If they work: Everybody loves you, thanks you, including audio reviewers, and this is progress. |
| Is there a great book on speaker design? | pythonic | Multi-Way | 5 | 9th June 2009 05:45 AM |
| FS Gainclone Great Chassis, Potted toroidal, great sound | PHilgeman | Swap Meet | 4 | 2nd May 2006 01:20 PM |
| Here is a great tip for you guys building aluminum chassis for your amps | russbryant | Pass Labs | 39 | 28th November 2004 01:19 AM |
