I have searched around and I have been unable to find a good match for a subwoofer amp that meets my requirements. I would like to find a DIY plan for a class ab amp that will output 400-500 watts continuous. This will be used to power a small sealed enclosure that will be eq'ed a bit to offset the natural roll off of the enclosure. I like the idea of Krell clones but they appear to be much to large, to expensive for this roll, and are class A which is really not what I want for this application. Any ideas?
#2 |
ESP P68
other also class AB+B will produce power and higher eficiency from normal class AB the original ESP pcb is highly recomended its plug n play and has very amazing results
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#3 |
Sakis - thanks for the suggestion. 300 watts is in the ball park and I will look into this if I can't find anything larger that is feasible. I suppose I can adjust my enclosure parameters and driver choice to use a little less power if need be.
| SET recommendations | ALF in AUS | Tubes / Valves | 11 | 16th November 2006 11:29 PM |
| Sub recommendations Please | jaybird | Subwoofers | 8 | 17th December 2003 06:55 PM |
| op amp recommendations | millwood | Solid State | 18 | 29th April 2003 12:49 PM |
| Page generated in 0.07047 seconds (67.21% PHP - 32.79% MySQL) with 10 queries |
