Old 30th April 2003, 10:03 AM   #1
Default Voltagr Reugulator NOISE
For sometime, I have been following conventional widom and replacing 78 and 79 regulators with LT 1085/6, LT323 and LM320/340 types. How wrong!!
I wanted to use lower noise units for a dac ; and so made some measurements on 5V units with 50mA current and 10uf tantalum output cap with an ac volmeter capable of up to 1 Meg with 0.5 uV or better resolution.
Result?
JRC 7805 - 40 uV - to spec
LT1086 - 150 uV - to spec
LT323 - 50 uV
LM340 - 60 uV
Why is the LT range so touted??
Does anyone know who makes the M5F7805L range of reulators; I want to check on spec as I have a whole bunch of them in my dac?
Has anyone designed/sell a pin compatible replacement on a pcb that costs less than £40 with say 10 uV or less noise wideband?
Old 30th April 2003, 10:23 AM   #2
diyAudio Moderator Emeritus
jean-paul's Avatar
Conventional wisdom is using 78xx regulators. As I found out too they are not as bad as people think they are. Some exceptions are 78Lxx ( 100 mA version, tends to oscillate easily ) and 78Sxx ( 2 Amp version, for some reason screws up sound when used as a replacement for 78xx ).
Could it be that the internals of the newer 78xx series differs from the old ones ? I can remember that I had to match 7818's because some gave 17.2 and some even 19 Volt. Newer 78xx regulators are very precise and noise is lower too. Negative 79xx series were famous for oscillation when used without cap at the output and without load. Nowadays they don't have a problem with that
It's only audio
Old 30th April 2003, 10:26 AM   #3
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default Re: Voltagr Reugulator NOISE
Originally posted by fmak
For sometime, I have been following conventional widom and replacing 78 and 79 regulators with LT 1085/6, LT323 and LM320/340 types. How wrong!![snip]
That is why some of us regard so-called "conventional wisdom" with a healthy dose of mistrust. Especially when the conventional wisdom is confirmed by undocumented, unspecified listening tests.
Jan Didden
Old 30th April 2003, 02:27 PM   #4
jackinnj's Avatar
but how do you know if you were measuring noise or ripple, noise superimposed on ripple ?
Old 30th April 2003, 06:13 PM   #5
Default Re: Re: Voltagr Reugulator NOISE
You can see it on the scope. Supply is regulated. Only the LT1086 showed ripple from the supply; other rejected as stated.
Old 30th April 2003, 06:33 PM   #6
diyAudio Retiree
Default Re: Re: Re: Voltagr Reugulator NOISE
Go back and make sure you don't have a bad part. Also, adjustable regulators allow you to bypass the adjustment terminal to lower the noise below fixed voltage regulators. I have found the LT 1086 to be a measurable and sonic improvement over fixed voltage three terminal regulators. I think you guys just what to save money with 78XX types. They are much cheaper. Why not build your own discreet transistor regulators?
Old 30th April 2003, 06:53 PM   #7
jam is offline jam  United States
jam's Avatar
Default My two cents worth!
You should listen to Fred. The difference between a good discreet regulator and a chip are usually huge. Much more than the difference between chip types.
I have replaced chip regulators in some rather expensive equipment with discreet regulators and always have had excellent results.
Not meaning to advertise for Fred but he has posted an exellent design in the forum, you owe it to yourselves to try.
Jam
Old 30th April 2003, 08:49 PM   #8
Default Re: Re: Re: Re: Voltagr Reugulator NOISE
Don't need to. Whatever people hear, go to the LT1086 data sheet; the noise voltage is 0.003% of output voltage which is 150 uV for 5V out. For a 7805, the noise voltage is 40 uV. Now the output impedances and other factors may differ, but that is another issue.
What have you measured about the 1086 which is better?
I agree that discrete regulators are better. Twenty, thirty years ago, we were building Japanese designs with current sources etc. which sounded much better. The problem now is that these and other designs are TOO big for stuffing into existing digital systems which may need 9-12 regulators. The only design I know off is the Audiocom regulator which can be plugged into a 78x or 79x designed board but they want £40 for one which to me is too much. Hence my post.
Old 30th April 2003, 09:13 PM   #9
jean-paul's Avatar
Hi Jam, are you refering to the schematic with the green leds and LM1086 ?
Jean-Paul
It's only audio
Old 30th April 2003, 10:46 PM   #10
jam's Avatar
Thumbs up Regulator King!
Jean-Paul,
This one.
Jam
Low noise transistor and noise figure Real_Macgyver Solid State 26 31st January 2011 02:34 PM
SL-10 Noise hifi-hospital Pass Labs 8 16th February 2009 10:23 PM
Red LED noise. GK Solid State 5 14th December 2006 04:12 AM
anyone tried this for low noise 5v? mlloyd1 Digital Source 1 25th May 2006 01:06 PM
DSP and DAC noise nFORCE Digital Source 4 29th April 2003 04:18 PM
Page generated in 0.15525 seconds (63.73% PHP - 36.27% MySQL) with 11 queries
