Whats a good capacitance to put accros the load resistor (8R) when simming an amp? I am not using a Zobel network in the sim yet, but am still trying to get stability. I know this has been discussed before but my searches didnt find anything. I have been using 10nf and now when i change it to 100nf I have an oscillator. If 10nf is too small I need to go back to the drawing board! Thanks in advance.
#2 |
2uF is often seen, because it is supposed to be similar to an electrostatic speaker. D. Self suggests that 100nF is a more difficult load, so it's probably a good value to test with if you want absolute stability. An output inductor helps a lot with this.
https://mrevil.asvachin.eu/ |
#3 |
Did you mean 2 nf?
#4 |
No, definitely 2uF. I wouldn't worry if your amp isn't stable into that, because it's not a normal load. Even 100nF is very high, but I think it's worthwhile making sure an amp is as well behaved as possible into difficult loads.
#5 |
just Google for wire/cable capacitance pF/ft - 10-50 pF/ft seems to cover all but the most exotic low inductance cable designs
the 2 uF direct load is an absurd standard - leakage inductance and series resistance of the ESL step up transformer would prevent the amplifier from seeing a pure C load of that magnitude |
#6 |
Piezo tweeters are typically around .2 to .3 uF, so someone hooking one of those up to the amp is kind of nasty, especially if there’s no R load to help dampen things out. Electrostats are sometimes modeled as 8 ohms paralleled with 2 uF (don’t ask me why, as someone already commented, real electrostats probably look quite a bit different). My current amp prototype shows the greatest over-shoot and ring around 20 nF, less than that the amp drives well by itself, and over that the output inductor progressively helps more and more.
#7 | |
It's good to test the amp with a wide variety of capacitance loads, but don't expect it to be stable under all conditions without the use of a series L-R network. Depending on the amplifier details, you can go as low as 1 uH in parallel with 2 ohms or so. When probing for stability of the amplifier itself, probe on the amplifier side of the L-R network. Most people will agree that a series inductance as low as 1 uH is sonically transparent. Others think that values up to perhaps 5 uH will not degrade the sound. In any case, be generous in constructing the coil and make it air core. The Zobel network (series R-C shunting to ground), is usually needed to stabilize the amplifier when it sees an inductive load or no load at all. If you want to go as high as a 2 uF load test, it is reasonable to put 1 or 2 ohms in series with it. Cheers, Bob |
#8 |
2 uF is -j4 ohms at 20k. If you really wanted to make sure your amp is stable into and can drive a fully reactive load, that would be the test. If you were going to be driving electrostats or banks of piezos it might be good to check. Probably a 10kHz test (-j8 ohms) is probably sufficient for even extreme loads, however.
#9 |
Thanks for the answers. One more question, would I be correct in assuming most speaker/cable combinations are an inductive load? (Not including electrostatics, or pizos). So do people test stability with capacitive loads because they are a more difficult test? (I guess if you have a long high capacitance cable that isnt connected on the speaker end you dont want the amp to go unstable. So much to worry about! Oh well, I guess thats what makes this stuff so interesting.)
#10 |
Just tried a series R with the load cap, makes a huge differance. Adding .1R lets me go from .01uf to 2 uf. Is this a resonable thing to do ? My phase margin goes fro 70 degrees to 30 degrees (still borderline stable? but the interesting thing, my gain margin increased from 6db to 12db!
| Mosfet Output Stage Capacitance | Nelson Pass | Pass Labs | 17 | 25th May 2012 10:47 AM |
| reservoir capacitance for power output | lt cdr data | Solid State | 0 | 7th July 2007 01:14 PM |
| Cartridge capacitance load? I have some questions! | Kuja | Analogue Source | 8 | 24th July 2005 02:18 AM |
| power transistor output capacitance | hienrich | Solid State | 3 | 26th December 2004 07:18 AM |
| Load capacitance specs for 16.9344 Mhz crystal? | Ruach | Parts | 0 | 4th June 2003 02:30 AM |
| Page generated in 0.38302 seconds (24.93% PHP - 75.07% MySQL) with 10 queries |
