Grounding your amplifier?
Old 30th April 2003, 04:36 AM   #1
thylantyr is offline thylantyr  United States
Default Grounding your amplifier?
Figure 2 is a block diagram of
an amplifier printed circuit board
with 10,000uf of capacitance per rail
mounted on the circuit board.
The board has a dedicated
inner layer ground and power
plane for power distribution.
Power comes in via a connector
J1 and the amplifier output is J2
connector.
If I ground all the active circuits
including the 10,000 uf capacitors
to the ground plane on the board,
will this work good or will the
charging/disharging of the 10,000uf
capacitors cause too much noise
for the active circuits?
Or
see figure 1 for plan b
..... second post.....
Old 30th April 2003, 04:38 AM   #2
Or....
Should I seperate the active
circuit ground from the power ground,
essentially, there would be two
ground connectors on the circuit
board, then each connector goes
to the star ground.
Old 30th April 2003, 05:04 AM   #3
JOE DIRT® is offline JOE DIRT®  Canada
JOE DIRT®'s Avatar
I dont think its an issue that you have 2 wires returning to the main voltage rail ground......there is is one thing that I have noticed in all the designs I have seen in the forums here...I have always placed a bleeder resistor off the main p/s caps...maybe I`m wrong from doing that
Old 30th April 2003, 07:04 AM   #4
This is what I'm thinking for the
ground plane on the circuit board.
The main input gnd connector is the black box and the black lines represents
the insolation on the plane to create
the mixed gnd planes to form a star
ground on the pcb.
The large current will flow to the
+V and -V power capacitors,
this should isolate the sensitive
active circuits from noise ?
The input gnd connector wires
will be connected to the external power
supply reservoir (not shown).
Is this ok?
Grounding your amplifier?Hide this!Advertise here!
some help on dac grounding, please federico moreno Digital Line Level 0 3rd April 2009 05:05 PM
Lions and Tigers and Grounding Problems, Oh My! DoZ Grounding... EchoWars Solid State 37 3rd August 2008 08:50 AM
Grounding problem of my OTL headphone amplifier ronardi Headphone Systems 1 17th May 2006 04:19 PM
LM3875 kit grounding, optimal grounding for separate amps and psu? findog Chip Amps 9 16th May 2005 09:27 PM
pre/amplifier grounding Alkis Tubes / Valves 4 27th February 2005 07:56 PM
