Some analyses of Tyimo Choke Loaded Class A Single IRFP240 MOSFET amplifier Fourier Analysis, Harmonics spectrum at 1 Watt RMS into 8 Ohm Looks nice. The power consumption for this first is: 755 mV / 0.54 Ohm which gives like 1.5 Ampere when using one PSU 14.5 VDC (Power supply Transformer is one Big 9 VAC or one Smaller 12 VAC ???) What is it Tyimo Shows very nice falling hramonics. THD is below 0.09 % not bad!Gain is low .. below x1 /lineup - Investigations In Audio
lineup |
#2 | ||||
Hi Lineup!
Why we aren't in the Pass forum?!? Greets: Tyimo |
#3 |
I have already been too much in Pass Labs.
I am only guest occational there. There are other that are more welcome ...... ... ... One country can only have 1 King. Two Kings are too much for any regime SEWA = pass pass = OTA also by Mads_K F5 = mosfet in pass labs B1 = in pass labs ... now is the time Solid State transistor forum learns how to use HEXFET! Not only Bob Cordell and the big guys ... should learn this. Nelson Pass is good with HEXFET from IRF But think if they learn in here in Solid State. If they will be thought how to use MOSFETs/HEXAGONAL Structures Die And so we will make better amps than Nelson Pass at about year 2015. This is my hope. We can do it! When Nelson Pass and Me and John 'jfet' Curl are dead 58, 68 years old already) we need a few to be able to take over the inheritaged knowledge. Two very promising for future are: Tyimo & Keantoken(16)
lineup |
#4 |
Here is AC analysis. Impressive ![]() As my first setup of your Real Circuit shows: 2.2 MHz has rolloff -3 dB 2.3 MHz something for -45degrees Phase .. almost the same. .. I could have a guess it has been trimmed, for this? One reason this amplifier can be so fast, is because the Voltage gain is low. Below 1. This is one benefit from avoid un-necessary high gains .. that the bandwidth can stay high. In short, very good ac behavior and phase. Superior to many other power amplifiers, I would say.
lineup |
#5 | ||||
Hi Lineup!
I am waiting meanman64's listening impressions. He is also biulding my amp. Greets: Tyimo |
#6 |
Did you have a particular part in mind for L2? The reason I
ask is I saw a little discussion on Tubecad about the fact that most chokes unless made for audio use distort AC a lot. Then the author recommends adding a air core in series with the iron core choke. The author compared this to adding a film bypass cap for an electrolytic cap. Here is one example of someone doing this. |
#7 |
Ummm... aaaaa... Nelson Pass published this idea with Mosfets I think like 20 years ago now... then he did the Zen... I did my DC coupled SE Mosfet, then Nelson did a ton more, and I didn't...
_-_-bear
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#8 |
I think it's just going to take a big gapped core. 120mH at an amp and a half is a tall order. Probably not impossibe, but beware of sticker shock.
#9 |
of course, we cannot be original as we are in this world of fast coomunications... this idea, the choque coupling, remembers the amplifiers from the fifties (great times). Into the fifties they used a transformer primary as the transistor or tube load, and the secondary was to the speaker. this one is nice...only 1.5 amperes.... low voltage....low power consumption and around 25 percent efficiency.... good idea..this one is very interesting.... post the complete schematic please. I know it is impossible to be the first to have ideas...now a days we can only produce Frankensteins products..as even if we create something, it belongs to mankind...someone had the same idea..or something alike, years or decades before.... hard to discover things now a days. Congratulations...lovely one. Carlos |
#10 | |
Yes, the air core measures better on paper, but in the reality you would lose the power efficiency because of the very high Rdc of the air core. You don't need to care about the distorsion of a good gaped iron core. Tyimo |
| Choke loaded LTP | jane | Tubes / Valves | 6 | 8th November 2008 02:25 PM |
| Choke Loaded Zen | hacknet | Pass Labs | 17 | 8th April 2004 05:45 PM |
| X-SOZ-X-BOSOZ.....choke loaded | Magura | Pass Labs | 23 | 27th February 2004 04:38 PM |
| Is this a choke loaded Xsoz? | Fuling | Pass Labs | 10 | 31st January 2004 12:20 PM |
| Page generated in 0.13316 seconds (82.12% PHP - 17.88% MySQL) with 11 queries |
