+/- rail electrolytic caps - need to be identical
Old 29th May 2009, 02:32 AM   #1
Ziggy is offline Ziggy  Australia
Account Disabled
Question +/- rail electrolytic caps - need to be identical
Hi guys, want to replace two Elna 5600uf caps in a 13 year old kenwood 2 channel receiver that sounds bloody amazing.........don't ask why.........it just does
My question is............do both capacitors need to be the exact brand, uf (within reason) and voltage (as per original or higher)?
The circuit has one in line bridge rectifier that is connected to the two caps which are in series creating the +and - rails.
Can different caps (brands, paralelled banks etc.) used to replace two same brand types affect the sound quality of the amp purely because they are not identical?
Old 29th May 2009, 03:19 AM   #2
ostripper is offline ostripper  United States
ostripper's Avatar
Yes, both rail caps should be the same value/ brand. Different caps have different ESR (equivalent series resistance ) , so , under load, you might hear a difference.
Different caps are more forgiving , you might even improve the sound. If you get some 6800uF @ 50/63V ones (CDE, nichicon,panasonic, etc) , you will have better bass, slightly more headroom. If you parallel 2 for each rail (2 X 3300uf) , lower esr !!
http://www.low-esr.com/LowESR_Trends_QT.pdf
PC's use paralleled caps in their super high current CPU supplies.
OS
Old 29th May 2009, 05:31 AM   #3
Account Disabled
Thanks ostripper. I'll chuck my original idea in the bin and purchase a few good ones and maybe paralell them.
Rob.
+/- rail electrolytic caps - need to be identicalHide this!Advertise here!
paralleling film caps with electrolytic caps jarthel Power Supplies 399 14th September 2014 09:33 PM
Does someone know these electrolytic caps? 12 Cents Parts 4 25th November 2005 09:26 AM
Electrolytic Caps jhead Parts 0 21st April 2004 10:11 PM
More Electrolytic Caps MRehorst Swap Meet 3 26th December 2002 10:56 PM
Electrolytic Caps MRehorst Swap Meet 5 12th December 2002 03:45 PM
