Old 28th May 2009, 11:02 PM   #1
Default AB Amp keep blowing fuse
I have an AB amplifier that keep blowing fuses.
Iam using the correct fuse.
It will power up then slowly the power light goes out after few second.
Thanks for some help.
Karl
Old 28th May 2009, 11:24 PM   #2
Hi! Can you post the schematic, or its link? There's got to be a trimpot to set the quiescent current, take a look at it to know if it's all the way to right or left... probably quiescent current is too high, and be careful, if the trimpot is set at max quiescent current, the output trannies will reach the Hades in less than two
seconds...
Old 28th May 2009, 11:36 PM   #3
Arcaman is offline Arcaman  Italy
Does it without any load connected ?
Have you checked if the voltage selector is in the right position, if present?
Old 29th May 2009, 02:19 AM   #4
nigelwright7557's Avatar
If you havent adjusted the presets then its probably the output transistors gone.
Anything else usually doesnt take enough current to blow the fuses although a shorted capacitor might.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Why does fuse keep blowing imhondamatt Car Audio 26 19th April 2009 08:14 AM
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 11:39 AM
Blowing my fuse (s) Jimlondon Chip Amps 7 7th March 2005 07:03 PM
Fuse keeps blowing Vivek Everything Else 4 1st August 2003 07:31 AM
Page generated in 0.08201 seconds (74.83% PHP - 25.17% MySQL) with 10 queries
