Dx amplifier, builder's thread
Old 28th May 2009, 06:30 AM   #11
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Here you see boards in transparency
This will allow you to conclude the image size to your etching.
Again... a nice work from Klaas Veenstra
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 28th May 2009, 06:34 AM   #12
Default You have detailed instructions to adjustment
also parts list (bill of material) and more details into the Greg home pages dedicated to Dx amplifiers.
http://users.tpg.com.au/users/gerskine/dxamp/
Old 28th May 2009, 06:39 AM   #13
Default Test voltages
Old 28th May 2009, 07:00 AM   #14
Default Specifications...the most important ones
attached.
Old 28th May 2009, 07:09 AM   #15
Default Suggested supply to the Dx amplifier
Each channel sucks 2.5A each rail from the supply.... 5 amperes will go to speaker (4 ohms).... 5000uf each rail.
So, this suggested supply is good to use together 2 channels if you operate those channels with 8 ohms speakers.
If you decide to use 4 ohms speakers, them double the electrolitic condenser value....or use one of those circuits to each channel.
Two supplies are suggested, as this will increase channel separation, dinamic power and sound stage.
Old 28th May 2009, 07:22 AM   #16
Default 300 watts supply is enougth to 2 channels
each channel will use 2.5 amperes fuse into the rails
each channel will have 5 amperes fuse into the output.
each channel will need 12.500uf to 15.000uf filters to each rail when operating 4 ohms
Old 28th May 2009, 07:26 AM   #17
Default Grounding
the input ground (lifted using 10 ohms resistance) is exclusive the input audio cable shield.
main chassis ground is needed...bolt and nut or solder wire to the metalic chassis...near the secondary center tape and solder this center tape into this ground.
Run wire from this point to the board ground, to the electrolitic condensers central point, to the speaker ground, potentiometer metalic caps (if wooden panel is used..a non conductive panel) and heatsing must be grounded too.
Attention to the input ground .... the ground connector into your RCA input cannot be grounded into the main ground..this ground..the input ground, is insulated from the main ground.
Power transformer primary is fused too.... use 2 amperes to 220 volts mains, or 4 amperes to 110 volts.
Old 28th May 2009, 07:43 AM   #18
Default Use a lot of capacitance into your supply..or you gonna face problems
watch this...without capacitor you should have enormous noises together your bass tones.
http://www.youtube.com/watch?v=KjE_ExOoWWs
Old 29th May 2009, 09:48 AM   #19
Default From time to time i will "call this thread"
to keept this one alive into the main forum page.
There's a lot of folks still buiding this amplifier.
regards,
Carlos
Old 29th May 2009, 10:29 AM   #20
lineup is offline lineup  Sweden
lineup's Avatar
Nice for you, but ...
I would let those people post to your topic, when and if they want to get some good advice from you, destroyer.
You have the good experience to guide other, epsecially beginners, to build your great circuits.
So I notice.
This we usually call 'bump' one topic.
Most forum this is not allowed.
Here in diyaudio is no problem, not for you DX and not for me Lineup or John Curl.
We have very nice and forgivening moderators.
But all do not like this thing. We must understand this.
If you have nothing new to add to your topic or just use some psronal pictures of your family to bump your stuff
this is not really what I would recommend.
Imagnine what would forum look like if everybody topic starter did the same
My GOD .. if so, I would not want to by a member here no more.
Because only 6.34 % of posts would be something of use for diyaudio members.
If somebody asks you a question
or somebody posts some bad statement to or about you
you or I have the right to reply. The right to self defence.
This is common justice.
And finally I add something to contemplate, to think about,
this was for one period my signature in this forum.
We know this from countless many many scenes in american movies.
The 'Miranda warning', from the US Police
Regars
Lineup - avoids to add empty bumps, because he likes our forum stay good
Miranda Warning:
You have the right to remain silent.
Anything you say
can and will be used against you in The Court of Forum.
Do you understand these rights?
.. no come, lets go to police house
Bump .. some short facts, in anglias:
Motivation
Many Internet forums show as their first page a list of the 2050 topics or "discussion threads" most recently posted to.
Someone wishing to keep a thread on this first page, or bring an old thread back to it will post a reply to it purely to do this.
If they are open about this, the post may simply be the word "BUMP".
Netiquette
Thread bumping is commonly considered a breach of netiquette
and some moderated forums forbid it.
Users may get around that by posting what is ostensibly a genuine reply. Sometimes this will mockingly contain the word "bump" in it, such as "Wandering the forum, he bumps into this thread...", or be a trivial question or response such as "Anyone?" Bumping old or inactive ("dead") threads is occasionally called "necroposting" or "thread necromancy", and the bumped posts referred to as "frankenposts". "Dead" threads that are reawakened are often called "thread necros". People who resurrect old threads are often called "threadomancers". On some boards, bumping a new thread with no replies in order to elicit a response is tolerated, but resurrecting an old thread that has run its course and has been inactive for a period of time (usually anywhere from a few days to a month) is prohibited.
The acceptable practice is usually to start a new thread and link to the old thread so that readers can become familiar with the background information.
"My Ninja Kiwi" is an example of a site that strictly does not allow thread bumping
- you can get banned after a single offense.
lineup
Dx amplifier, builder's threadHide this!Advertise here!
Copyright ©1999-2017 diyAudio
