Old 27th May 2009, 04:52 PM   #1
Rob_S is offline Rob_S  United Kingdom
Default 2SC5200/2SA1943 Toshiba or Fairchild
I'm looking to build an amp using 2SC5200/2SA1943 devices as the outputs, is there much difference between the two manufactures Toshiba/Fairchild?
Also good places to purchase, that would be cheap but original devices.
thanks
Rob
Old 27th May 2009, 05:20 PM   #2
Bigun is offline Bigun  Canada
Bigun's Avatar
I will know in the next few weeks how the Fairchild devices work, or at least if they don't work. I selected the Fairchild TO-220 devices from DigiKey for the TGM amplifier. I don't need the power levels offered by the larger T03 packages. I also suspect the TO-220 packaged devices are not targeted for fakes.
From digikey they are quite reasonably priced if I remember.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 27th May 2009, 09:24 PM   #3
taj is offline taj
taj's Avatar
I don't know which is better. They have different case choices and the Fairchilds are a little cheaper, but they're all pretty cheap anyway.
Digi-key is a good safe source for the Toshiba's. They get them directly from Toshiba, but sadly they don't carry many different devices. They also list the Fairchilds, but they never seem to have stock. I haven't looked for a while though.
..Todd
Old 28th May 2009, 01:38 AM   #4
CBS240 is offline CBS240  United States
CBS240's Avatar
I may be mistaken but didn't Fairchild used to be Samsung? Samsung once had an excellent semi fab production, particularly small signal stuff. My experience with Fairchild's Q-fet hex type power fets is quite positive. I'm not as familiar with their power BJTs.
BTW, Mouser seems to have lots of Fairchild stock.
Old 28th May 2009, 02:45 AM   #5
MJL21193's Avatar
History of Fairchild
Old 28th May 2009, 03:16 AM   #6
rephil is offline rephil  Belgium
Hi Rob_S
Do a search to this thread here :
Where in Europe do you buy your 2SC5200-O and 2SA1943-O for AAK's Symasym boards ?
I hope this helped you.
Best regards
rephil
Old 28th May 2009, 04:12 AM   #7
CBS240's Avatar
Old 28th May 2009, 04:28 AM   #8
MJL21193's Avatar
Traitorous Eight
Old 28th May 2009, 02:42 PM   #9
jaycee is offline jaycee  United Kingdom
From what I remember they did buy part of Samsung Semiconductor's portfolio. I think this was mainly discrete devices and integrated circuits, leaving Samsung to produce DRAM and other memories
Old 28th May 2009, 04:13 PM   #10
Thanks rephil for the UK supplier for the Tosh devices.
From others comments there looks to be little difference between the quality of the devices?
thanks again
Rob
Toshiba 2SC5200/2SA1943 Spice Models thmios98 Solid State 20 21st November 2011 03:27 PM
Toshiba 2SA1943 and 2SC5200 Transistors Archimedes Swap Meet 10 7th November 2008 03:56 PM
Toshiba 2sa1943 + 2sc5200 clear out ANTHONY2181 Swap Meet 0 21st June 2004 11:40 PM
Page generated in 0.09594 seconds (78.88% PHP - 21.12% MySQL) with 10 queries
