2SC5200/2SA1943 Toshiba or Fairchild
Old 2nd June 2009, 04:53 AM   #21
wojtek5001 is offline wojtek5001  Poland
Default what about STMicroelectronics?
2sta1943
2stc5200
Wojtek
Old 2nd June 2009, 12:55 PM   #22
wg_ski is offline wg_ski  United States
Default Re: what about STMicroelectronics?
Well, the circle is complete - even ST is making clones of that transistor now. Now there may be very slight sonic differnces between all of them - but in terms of basic characteristics and ruggedness, one is probably just as good as the other. If someoene wanted only a Toshiba, they could go out of their way to get it if they wanted to. The rest of us get what our distributor stocks. And with all the major players making them "My dist. doesn't stock Toshiba" won't force anyone anywhere to go get trannies from questionable sources.
I wonder if it was the industry's response to all that counterfieting going on. If there are a number of legitimate sorces instead of only one, who needs fakes form China?
Old 3rd June 2009, 09:49 AM   #23
burbeck is offline burbeck  United Kingdom
Originally posted by jaycee
Profusion don't claim to supply the Toshiba ones, although they do link to their data sheet. From what I've heard, Profusion supply clones made by Semelab, also sold as Magnatec by Farnell and others.
Hi
well its true that they do not say that these parts are Toshiba on their web site describing the manufaturer as 'other'. i have used lots of these parts from them always been the real thing, if anyone still not convinced give them a call to verify.
Profusion are a very good reliable company.
regards
bob
Old 3rd June 2009, 02:45 PM   #24
rephil is offline rephil  Europe
Hi jaycee,
If you don't ask, you don't know. I did ask and they answered that they only sell original parts. Profusion is OK for me.
I have got without any doubt good original Toshibas transistors at low cost.
Best regards
rephil
Old 3rd June 2009, 03:17 PM   #25
bbp is offline bbp  China
It seems that the ST's has a low Cob
226pF comparing to TOSHIBA's 360pF
calm down and enjoy your time in experiment
Old 3rd June 2009, 05:01 PM   #26
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Which means? explain please, which would then be best?
Another thing I like to know, are those specs always 100% reliable?
sometimes we know very little, and sometimes we know too much
Old 3rd June 2009, 05:30 PM   #27
Change the test conditions and you can get that much variance in the result.
Old 4th June 2009, 01:30 AM   #28
Yes,TOSHIBA shows the test condition but ST not
Old 4th June 2009, 06:17 PM   #29
ceharden is offline ceharden  United Kingdom
Default OnSemi MJL3281/1302 in Crest
Hi there, thought this might be a sensible place for this question.
I've got a Crest CA12 for repair which uses the old Toshiba 3281/1302. It needs a whole channels worth of devices (22). Obviously I can't use the Toshibas but I'm wondering if the OnSemi's might be a good alternative. They do a few different versions so one of them must be suitable. Comparing specs, the Cobb of the Onsemi's is higher but other than that they're equivalent or better.
Any comments?
Old 4th June 2009, 07:22 PM   #30
EWorkshop1708 is offline EWorkshop1708  United States
The On-Semi version of the 3281/1302 will replace the Toshiba just fine. They are really rugged transistors. On Semi stuff is high quality, and I've not had any failures. They also make a higher-powered 4281/4302 series with more gain, and slightly more power rating.
Now about the Fairchild version of the 5200/1943............Apparently the same die is used in all of the different sizes, they are just different packages according to the datasheet.
It would be nice to get a bunch of the 50W and 80W TO-220 ones. True power transistors as drivers, without the huge size. Even as a big power amplifier, you can parallel more devices in a smaller space with TO-220.
The other advantage of powerful TO-220 would be making a small compact power amplifier, and having devices with a really High SOA.
Those are the biggest TO-220 I've ever seen. The Power devices are interesting as well, being the fact this transistor is in more packages than anyone else offers, that makes it very desirable IMO.
Imagine if On-Semi made a 3281/1302 in a TO-220 package, that would be killer.
You can call me Mad Professor, building crazy experiments in my Electronics Workshop
2SC5200/2SA1943 Toshiba or FairchildHide this!Advertise here!
Toshiba 2SC5200/2SA1943 Spice Models thmios98 Solid State 20 21st November 2011 02:27 PM
Toshiba 2SA1943 and 2SC5200 Transistors Archimedes Swap Meet 10 7th November 2008 02:56 PM
Toshiba 2sa1943 + 2sc5200 clear out ANTHONY2181 Swap Meet 0 21st June 2004 10:40 PM
